Can you quote these fault codes?I did a basic scan of the van and had some fault codes stored, I cleared them but the heater still didn't work![]()
Put up a pic of your wiring of the plug at the telestart, let's see if there is anything amiss there first.
I'm afraid the reader couldn't reach the Webasto. Seems to be just generic engine OBDII-codes, and probably not correctly decoded as the codes/explanations are really strange - referring to intake/exhaust valve controls.Don't think any of those would cause a problem though?
I just reuploaded the photos in my previous post.Can't read anything on the above wiring diagrams - I know that my eyes are old but can hardly make anything out.![]()
Definitely better to attach as pdf-files, the Forum compresses the imagesI just reuploaded the photos in my previous post.
Let me know if it is good enough, if not I will post pdf.
Pics still not good.
I am beginning to wonder if the pin 2 may be correct but the telestart is not a Lin-Bus one so is only putting out W-Bus protocol.
These telestarts are difficult to decide what they are as I have tested one that isn't marked LIN but could only see a signal on pin 5 with the scope, nothing on 2,3or 4. Unfortunately I haven't got any LIN marked ones to play with as I don't use them.
