Skyliner123
Hi all,
Our T6 has a Webasto airtop 2000 stc diesel heater fitted complete with the external temperature sensor and runs from the rotary dial. When we run it on around the 3rd marker on the dial it heats the van up to around 21C and then slows down the fan and then stops altogether. Without touching it again it will cut back in again but only when the temperature has dropped to around 14C (I have an internal temperature and humidity product close by the Webasto temperature sensor so can see the rough temps). Is this normal as I would have thought it would kick back in before dropping that much?
cheers
cheers
