Warranty work required following 2 year service
Troj
Manufacturing Engineer
Just had the 2 year service done at Listers, Coventry. A couple of faults were identified: An oil leak and SCR fault/update required (something about a fault with the adblue system).
Regarding the oil leak, I fear it may be the much talked about crank seal issue, as they suggested they would probably need the van for two days :rolleyes:
  • Wow
Turns out it was the front crank seal. Now has the revised seal so 'shouldn't be a problem again'. The rear crank seal is ok and is apparently far less troublesome than the front.
