He will still only have 1 reversing lightTwenty20 leds in ours too , plenty of light.![]()
Just replacement bulbs - cheap option
LED replacement rear lights - nice to have![]()
The H7s use two lamps in each light. One on for dipped, and both on for main beam.No worries. Thanks for the advice. Surely that still relies on one lamp for two functions still which is the issue with the H4?
Twin reversing lights on my 2019 panel van Highline?He will still only have 1 reversing light
Mine has reverse light n/s fog d/sTwin reversing lights on my 2019 panel van Highline?
I thought it was only one, bought a single Twenty20 Led to go in it, and when I checked to make sure it worked I realised there was one the other side![]()
I meant the H15 H7 upgrade. The H15 reflector still has to function for hight beam and drl so will have the same issues as the H4The H7s use two lamps in each light. One on for dipped, and both on for main beam.
Really ? Halogen units or E3's?Twin reversing lights on my 2019 panel van Highline?
It’s not really the same issue.I meant the H15 H7 upgrade. The H15 reflector still has to function for hight beam and drl so will have the same issues as the H4
No, it doesn't.I meant the H15 H7 upgrade. The H15 reflector still has to function for hight beam and drl so will have the same issues as the H4
So does mine, need to work out how to make both sides work as the bulbs etc are there.Mine has reverse light n/s fog d/s
Check the connectors to see if all 6 pins are used. If not they will require additional cable running like mineSo does mine, need to work out how to make both sides work as the bulbs etc are there.
VCDS option?
Thanks will doCheck the connectors to see if all 6 pins are used. If not they will require additional cable running like mine
Those are factory LED lights. The only bulb is for the indicator. The headlights have built in LED modules.On my 2019 T6 Kombi my full headlights have started to show a bit blub/rainbow colours on the top edge of the light but I'm confused if I can even change out the bulbs. I think I have the H7 LED's as pictured below but presumably these bulbs can be replaced? If so which bulbs do I need?
Is the option then that I have to change a whole headlamp out or just live with the rainbow/bluish edges?Those are factory LED lights. The only bulb is for the indicator. The headlights have built in LED modules.
The blueish tinge seems quite normal to me.Is the option then that I have to change a whole headlamp out or just live with the rainbow/bluish edges?
