T6.1 OEM LED Headlight retrofit
Hi,
Just looking at the T6 LED to T6.1 LED front light conversion. Is it just plug and play harness? How much are the adapters?
I will assume that your headlights are working in automatic mode! what car do you put them on?
Hi,
Hi. I would like you to write to me by Telegram(My contacts are at the end of the instructions). The adapter is made in two different configurations, I need to ask you questions
Hey, Recently I received from @F-roger this adaptor, for may T6-2019 which I made a retrofit from h7 head light T6 to T6.1 full led light with afs control. Everything was perfect with Alex, from order to final installation, coding and testing. I was all the way guided with all the information that I needed and that I asked for. Now I can say with confidence that despite my expectations, it was an easy process to installing everything. I am fully satisfied for the final product, congratulations Alex! I definitely recommend.
Hello everyone,
Just wanted to say thanks to F-Roger.
I have managed to convert my T5.1 to T6.1 with full led headlights. But it wouldn't be possible without his adaptors and personal help. Managed to do the coding as well, have not done it before in my life.
And if anyone needs help locally give me a shout. Located at SG9, Buntingford.
Fell victim to the glue and tar remover, so selling my old units if somebody is looking for project/retrofit
Asking whether it is plug and play.
A few posts above, I posted the instructions from the adapter.
It all depends on which car you have and which headlights were installed from the factory.
Almost all cars need to change the BCM encoding. The set of wires itself has all the necessary connectors and is connected to the factory connectors.
vw t6.1 headlights are fully controlled by Can. The only contact of the low beam headlights is used as emergency power (in the rays of Can damage).
to install vw t6.1 headlights on older cars, an adapter is required that can generate the correct messages in Can
I made this device and can provide a ready-made retrofit kit
View attachment 209787View attachment 209788
Hi mate, I’d be interested in one of these looms please
Hello everyone,
Hi I’m looking with interest at your post I’m in middle of changing from 5.1 go 6.1 and have the (think v1) transporter HQ 6.1 copy led lights which you put led bulbs in. Any ideas what I might need to make them work please?
Thanks Jamie
Vw t6.1 2020, jai un error vcds
131106 nacido el 30
U1407 (175) señal no plausible
¿Puede el bus de datos nm ser inverosímil?
T6.1 front OEM LEDs appear under VCDS as two independent controllers.
Address D6: Light Ctrl Left 2 (A31)
Part No SW: 992 941 571 AA
HW: 992 941 571 A
Component: LED1L H08 9002
Address D7: Light Ctrl Right 2 (A27)
HW: 992 941 571 A
Component: LED1R H08 9002
There is no coding on these and no coding on the BCM. Any modifications need to be done via BCM adaptations, retrofitting included.
Hi!!..Can the adaptation and parameterization of the control units be done with VCDS? I have purchased the Kufatec wiring and sensor kit.
Everything is simple with adaptations! This is possible with VCDS. But it is not possible to download a dataset from VCDS
¡Todo es sencillo con las adaptaciones! Esto es posible con VCDS. Pero no es posible descargar un conjunto de datos desde VC.
¿Existe alguna página donde pueda comprar y descargar esta información? He encontrado información en un foro francés para adaptar muchas opciones para t6.1, pero nada para faros LED, por desgracia.
thanks.
