hello mmi, what value should be for rb3 where I marked
This set?
Hello !
I finalized the retro fit installation of the front fog light.
Tried to code it with ODBeleven.
It seems to be that the cornering lights are working pretty well , nevertheless when I try to switch on both lights nothing is happening.
I tried to put these values (provided by fog lights seller) :
Lampendefektbit 12 : 38
Fehlerort byte 12 : 22
Fehlerort byte 13 : 42
Lampendefektbit 13 : 23
after I tried what has been suggested here, but not much results :
Lampendefektbit 12 : 56
Fehlerort byte 12 : 34
Fehlerort byte 13 : 35
Lampendefektbit 13 : 66
Could someone help me out ? My VW is a T6.1 April 2021
Thanks a lot !!!!
Thanks, that's exactly what I did.Revisit Encodings
The BCM can report light switch position. Does it "see" fog light switch operated - does it see other light switch positions?Thanks, that's exactly what I did.
I'm very surprised to see that the corner light works well (even when reverse) but not the fog lights when switching ON the switch... Any idea ? Is there something to code regarding the new switch ?
Thanks !!!
It doesn't make sense - the Function 10 is the adaptation and there definitely are no bytes to work with. Are the instructions for T6.1?Also, in the instructions provided by the company who sold the kit, it's written to activate byte 7 bit 3 and 5. But I did not find how to do it in the long coding, nothing about byte 7 - any idea ? Thanks
Hi,
Thanks for the answer. I just checked the live status of the switch, and it's written for the fog lights 'not codded'.
Surprising, because I put all values mentioned previously for the "Leuchte 12&13".
Yes, when switching on and off the other lights, I do see the correct status. Just the fog lights status is not modified and stay on not coded :-(It doesn't make sense - the Function 10 is the adaptation and there definitely are no bytes to work with. Are the instructions for T6.1?
I'm not sure if this helps but below how the light switch is seen with VCDS - do you see the other switch positions correctly?
a) van with fog lights - light switch OFF
(b) without fog lights - light switch OFF
Did you verify the wiring from the switch to the BCM?Yes, when switching on and off the other lights, I do see the correct status. Just the fog lights status is not modified and stay on not coded :-(
Hmmm... latest Golf... unfortunately I have no idea about the compatibility.I bought a non original part, the vendor told me it is for the latest golf which is compatible with the t6.1. Hope it's correct, I attach some pictures
-BD seems to have Auto position. Please Google for pictures by the part number...5G0941431BF or 5G0941431BD
hi,
