cheersYour airbag will fit that wheel fine. If the controls match what you have on your van then that should all work fine i would say.
I would agree but if it’s not from a T6 you would need to swap your buttons and wires from your wheel into this one
Unaided flying ?
This thread is turn into animal cruelty. First @Insert Coin is going to kick the dog now @T6180 is launching the cat ! All over steering wheels![]()
OK, think the fish are safe, just found this, hopefully all will be good in the hood & it will fit OK, right tags for the airbag, I can swap my fascia so fingers crossed. Came off a recent car too so hopefully good nickView attachment 33926 View attachment 33925
That looks the same as mine, so should fit fine once you swap out the switch gear.
I feel bad for @T6180, because we were fitting his tomorrow. I didn't even realise VW had different fixings for the airbag, because mine was off a MK7 Golf and fitted fine, using my airbag.
Few i was worrying about the fish as well then
That is a heated wheel as there is a extra plug and wires for the heated grips. I have them on mine, but no plug obviously to connect too, but it does not affect the function of other wheel controls anyway. If you swap your wires and switches on to that wheel your be good to go![]()
Heated? It's the same as mine. Can that be wired up and activated?
@Tourershine @Spookybear that's it ...carry on with the sympathy....I need it ....I even offered to cut some onions to mask the tears
New Steering Wheel purchased and collected....
happy days, but is it fitted, c'mon, what ya playing at, get out there & make it so![]()
Thats @Tourershine job for xmas morning![]()
