Anyone have a Euro 5 Highline?
Yep, but as its highline it had cruise on the stalk already, so I only had to swap the wheel and airbag (I bought a MFSW that already had the same button layout as the standard MFSW).
Thanks for your quick response!
Since posting I had it back off and swapped the loom out on the airbag.. still the same fault and no buttons working other than the 2 mentioned and the horn. I don’t think I am actually able to swap the buttons as they are different in shape, but I could possibly look into changing the internal wiring within the wheel itself, or can you not disconnect the buttons from the loom in the wheel?
Yeah my original wheel was the same as in your first photo mate, so I am unable to swap the buttons over.
I have looked at the others that have been swapped over in this thread but none appear to have ACC - I think that is what’s causing me the issues! But it is odd that the buttons aren’t even lit up or anything and I have re-used the existing loom from the original airbag.. I thought it would of been a like for like swap
I really fancy a mk7 golf dsg steering wheel as raceline fit to there t6 vans , i am not a fan of the highline wheel at all. I wondered if anyone has ever messed with changing wheels, i dont no if the wires/plugs are there for a straight swap but it cant be much of a job if raceline do it ?
The Lin language of the buttons is different ie the software in side them
If you want a fancy flat bottom wheel that works with paddle shift drop me a message as i have the answer
Hi all.
Apologies in advance as I'm a T5 driver but seeing as there is lots of helpful info on here I thought I'd ask.
I've just bought a 2005 Caravelle with T5.1 facelift and the owner fitted a Mk7 Golf steering wheel. Nothing works on the steering wheel other than the horn and hopefully air bag lol.
Any pointers to look at to get any of the buttons working and of poss the dsg paddles. Does anyone know if its been done before. I'm ok with coding with VCDS and Launch diagnostics so just looking at some checks on what to look for.
TIA.
