They look good where about did you get the panels and trim from please
Right...I've hit a brick wall!!!!.......I didn't realise that only having a single sliding door would be such a pain....I went to mock up the caravelle door cards and realised that the 'panel' side window is a different length than on a sliding door...I assumed they would be the same....so now I have 2 pairs of door cards, one caravelle and one shuttle that I can't use.....
I'm tempted to cut the shuttle ones up to make a single door card for the panel side...for example cut one in half, measure it up the and cut a 2/3 inch strip out of the other side and try to bond this together and recover .. a lot of work but will solve the problem and at first glance the appearance would be the same.
Unless anyone is aware of a OEM trip panel off another model (multivan/shuttle/caravelle) that fits a single sliding door model?
Cali Campers in New Milton, i believe.
@T6180 did you remedy this? That Hinckley £200,000 show camper had a single slider with OEM panels, I’m sure, so they must have found a way around it.
Also, was your van a PV before? Is your window OEM or aftermarket?
I ask as I wonder if these trims will fit a sliding door with aftermarket windows (what with all those clips).
All change..it has a knock in effect.. pillars mean roof linings too.. door cards and window surrounds are fine together but as soon as you do pillars you open a can of expensive worms.If you use the Caravelle interior do you have to use the Caravelle pillars tops too or do the Kombi originals still butt up ok?
