Sure, when I find some spare time as I am very busy lately.Can you explain how did you do it ?
I'm half way through fitting and have hit a problem.
I'm really struggling to remove two pins from the BCM so I can attach wires to them.
They are pin 18 & 19 (B) which are the smaller ones in the middle.
I've split the plug, and can release the pin so it slides easily a little way, and then the 'tang' is getting caught and I cannot work out how to release it.
Does anyone know how to do it please?
HI, the switch is OK, all the lights are OK. The parking assist start OK in the cluster but how the Sensors not working the parking assist ends.1 Fault Found:
1113618 - Parallel Parking Assistance Indicator Lamp
B10FE 12 [008] - Short to Plus
fix this first
I would love to know how you work this out, how on earth do you know that 'SWA_0x1A' is related to the RTA display.View attachment 78166This two Adaptation channel make your RTA work... it may work only with the 1K8919472C... Thanks for Robert and mmi for the Help!View attachment 78167View attachment 78168
...... that would make perfect sense, but, the slave is working correctly..... my left mirror lights up when a car is in my left side blind spot and the RTA works when a car approaches from the left.It looks like your slave is disconnected, check 12v, ground and canbus high/low is reaching the slave unit
Seems to be a feature of OBDeleven. Mine is the same when scanned with OBDeleven. However, VCDS shows both.When I scan in 3C Lane Change Assistant Right I only see the master (686B), never the Slave (685B). Most other scans I have seen do show the Slave.
I'm using OBDeleven, could that be why?
Mine reached 2 x 100% in less than 80 km. However, converging of dynamic angle offsets seem to last significantly longer - though not a noticeable change in operation.And how about the Callibration, can anyone explain how that works please? And how long it is likely to run for?
That's interesting - the counter going faster than actual mileage. A couple of OEM ones (+mine) accumulate the counter much slower than actual mileage, approx. at rate of 1/3 of actual mileage.Status is running
Auto Calibration, percent, progress, Master 1218.00km
Auto Calibration, percent, progress, Slave 100%
Distance of object 4 100%
I can't work out how this works. Since the Blind Spot has been working I have covered approx. 500 miles/800 km.
What does the KM figure actually mean? It doesn't seem to go up at the same rate as I drive, and it started at something like 900km. Doesn't make any sense!
The 3C-Lane change Assistant has been added on Gateway Installation List??It still leaves me with an error to deal with 'Lane change assistance control module (No signal/communication)' Can anyone advise how to best approach this please?
(as far as I know the system is working exactly as it should)
It's not too late -maybe I should have got VCDS instead!
Thats true, but I think mod wise I have done everything I can..... there is nothing else so I really don't think it would be worth it!It's not too late -![]()
Yes, it just accumulates km's at the 1/3 rate.Does 'Master' just keep clockling the Km's, or will it change to 100% one day, anyone know?
Yes, that's the Gateway Installation List.Well, that is an interesting question. If I remember correctly when I scaned for the first time OBDeleven did something called 'AUTOCODE GATEWAY LIST' which added 3C Lane Change Assistant Right to the list of moduls, but is that the Gateway Installation list you mention? I don't know, so next time a connect with OBDeleven I will have a look and see if there is something I've missed.....
Thanks for that, I will give it a try and see what happens. If it doesn't work then, as everything seems to be working properly, I guess I will just have to live with it... or maybe get someone who knows what they are doing to take a look.Yes, that's the Gateway Installation List.
Perhaps you could try manually untick the 3C, cycle the ignition, chek the faults, then manually tick the 3C again, cycle ignition, check/clear faults.
There has been a couple of incidents where OBDeleven Gateway Autocode hasn't fully succeeded to add new modules.
