Battery Roamer 230SB install in van . . .
been busy so haven't had the chance to post . .
We had this 100ah Renogy in there . . . (200A isolator, 125A MIDI fuse and cable under floor to passenger seat base.)
plus the Victron BMV712 shunt
once removed we have this . .
sizing the Roamer up . . .
using the same ply wood and foam . .
it was sitting too high.
the battery fits super snugg between the front lower lips of the seat base.
the bottom middle was being pushed up by my 20mm copex for the seat base link cables.
i also noticed that the ground stud domed nut under the carpet was also stopping the front of the battery going any lower . . . as was the seat spacer block under the carpet.
after a bit of jiggling, i decided to go with the foam pads on the rear back and bottom (to offer some cushioning to vibration). . . and remove the ply wood supports.
but the same straps to hold the battery down. (wrapped round battery and upper seat base, front to back)
next up was the Victron shunt, i had this screwed to the front wood plate before . . . now i didnt have room, but there was a nice space down the side of the battery . .
so i used a 4x4 adaptable box 9 i have these to hand in the van anyway) to house the shunt . . ( i also cut the shunt ends off so it fitted in the box better)
the battery uses M8 bolts, the shunt used M10 bolts.
also noting what side went to the battery and what side to the van chassis . .
next us was the fuse and isolator switch . . .
i tried the 50mm2 cable at first, but i didnt have luggs big enough to fit . .
so i dropped down to 25mm2. . .
i also went for a 200A fuse in the MEGA fuse style . . M8 bolts.
cable, fuse, fuse holder, heat shrink, crimper . . . . job done.
the long M8 bolts worked well holding down the main feed and the shunt temp/power lug.
i love these style of terminals . . they are great . . . especially with the integrated cover - awesome.
the fuse sits be the side . . . and the seat base bolt is used for the 25mm2 chassis ground ( paint scratch off with emery cloth for a good connection)
profile wise . . . we have this sticking above the base where the seat runners go . . . about 5-10mm.
id already cut the carpet to allow the 20mm copex to sit back and allows the main cable to come up without chafing on the battery case . .
so at this point the isolator switch was fitted and screwed to a ply panel . .
id used split 20mm copex to protect the "thin wall" 25mm2 cable from any rubbing from vibration for a bit of saftey . .
we ended up with this . . .
a quick check with the seat ontop showed good clearance . . .
next up testing . . . . .
"Roamer SMART5, XTREME & HOME: 12V-48V LiFePO4 leisure batteries for campervans, motorhomes & boats. 100Ah-460Ah, Bluetooth BMS, 12-year warranty."
roamer.com
