Reversing Camera - Lowline to Highline Upgrade/Retrofit
HI i have problem with my camera, just fit that and is black screen. Any sugestions
Code:
Sunday,01,November,2020,17:32:41:00009
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 20.4.2.0
Data version: 20200730 DS317.0
www.Ross-Tech.com
VIN: WV1ZZZ7HZJH15****   License Plate: 181D
Mileage: 86850km-53966mi   Repair Order:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 02 03 04 08 09 10 15 17 19 25 56 5F
VIN: WV1ZZZ7HZJH15****   Mileage: 86850km-53966miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
Address 01: Engine (2D2D2-CXHA)       Labels:. 04L-907-309-V2.clb
   Part No SW: 04L 906 056 KG    HW: 04L 907 445
   Component: R4 2.0l TDI   H02 3771
   Revision: 23002001
   Coding: 00254014432401090000
   Shop #: WSC 02762 790 50316
   ASAM Dataset: EV_ECM20TDI03004L906056KG 004004
   ROD: EV_ECM20TDI03004L906056JS_004.rod
   VCID: 7CF741F7F7EB6E664F-8028
No fault code found.
Readiness: N/A
Address 02: Auto Trans (J743)       Labels:. 0BH-927-711.clb
   Part No SW: 0BT 300 046 J    HW: 0BH 927 711 G
   Component: DSG DQ500-7F  H11 5301
   Revision: 00H11V01
   Coding: 0014
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_TCMDQ500021 001001
   ROD: EV_TCMDQ500021_001_VW36.rod
   VCID: 3D718CF3AC71A76E38-8068
Address 03: ABS Brakes (J104)       Labels: 7E0-907-37x-MK100ESC.clb
   Part No SW: 7E0 907 379 P    HW: 7E0 907 379 M
   Component: ESC           H06 0133
   Revision: 00000000    Serial number: 60828000000278
   Coding: 517E4098256784858A750277A48A21E679F100
   ASAM Dataset: EV_Brake1ESCCONTIVN75XGP2 011001
   ROD: EV_Brake1ESCCONTIVN75XGP2_011.rod
   VCID: 3F8DF6FBA67DB57E2A-806A
1 Fault Found:
8285 - Databus
          U1121 00 [009] - Missing Message
          [New feature! Extended UDS fault detail is only supported by current gen. interfaces]
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 240
                    Mileage: 86850 km
                    Date: 2020.11.01
                    Time: 15:54:22
Address 04: Steering Angle (G085)       Labels:* 6R0-959-654.clb
   Part No SW: 6R0 959 654     HW: 6R0 959 654
   Component: LENKW.SENSOR  H07 0070
   Serial number: 12031813470332
   Coding: 01
   ASAM Dataset: EV_LWSKLOVW25X 005001
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EF34BFFE1F77C7661-802A
Address 08: Auto HVAC (J301)       Labels:| 7E5-907-047.clb
   Part No SW: 7E0 907 047 AK    HW: 7E0 907 047 AK
   Component: Climatic-T5   H22 0708
   Revision: 00001002
   Coding: 0000000003
   ASAM Dataset: EV_ClimaticT5 A01003
   ROD: EV_ClimaT5Basis.rod
   VCID: 73E56ACBDAB5211E1E-8026
Address 09: Cent. Elect. (J519)       Labels:. 7E0-937-BCM-V1.clb
   Part No SW: 7E0 937 090 C    HW: 7E0 937 090 C
   Component: BCM PQ25 Max4 H82 0752
   Revision: B9082001    Serial number: 4000 088180979
   Coding: B8A430B84AF3343193284FF47EEB8E7DFF8470FF60CC6D60330400220840
   Shop #: WSC 02762 534 168286
   VCID: 2B55B2AB4A0539DE96-807E
   Subsystem 1 - Part No: 5K7 955 559 C  Labels: 5K7-955-559.CLB
   Component: RLS 230318 04  47  0106
   Coding: 0228EE
   Subsystem 2 - Part No SW: 7E0 959 801 P    HW: 7E0 959 801 P
   Component: J386__TSG_FT  004 0653
   Serial number: KU0KU014031880731043
   Coding: 1400B0
   Subsystem 3 - Part No SW: 7E0 959 802 P    HW: 7E0 959 802 P
   Component: J387__TSG_BT  004 0653
   Serial number: KU0KU026031880852011
   Coding: 0400A0
   Subsystem 4 - Part No: 7E1 951 172
   Component: DWA-Sensor 00  001 0104
   Coding: 000000
   Subsystem 5 - Part No: 1K0 951 605 F
   Component: LIN BACKUP HO  H01 0008
   Coding: 000000
   Subsystem 6 - Part No: 7E1 951 172
   Coding: 000000
   Subsystem 7 - Part No SW: 7E0 959 442     HW: 7E0 959 442   Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H02 0103
   Serial number: 39180000256380058094
   Coding: B0FFFF
Address 10: Park/Steer Assist (J446)       Labels:| 5Q0-919-294.clb
   Part No SW: 1K8 919 472 C    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0480
   Revision: --------    Serial number: 39331727500488
   Coding: 0071151051
   Shop #: WSC 00020 999 12345
   ASAM Dataset: EV_EPHVA18VW364GP00 001007
   ROD: EV_EPHVA18VW364GP00_VW32.rod
   VCID: 377D9EDB8E4D8D3EE2-8062
1 Fault Found:
12718592 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 240
                    Mileage: 86850 km
                    Date: 2020.11.01
                    Time: 15:54:22
Address 15: Airbags (J234)       Labels:| 5K0-959-655.clb
   Part No SW: 7E0 959 655 J    HW: 7E0 959 655 J
   Component: VW10Airbag021 010 0018
   Revision: --------    Serial number: 003EK000SVAK
   Coding: 000000000000000000000000000000003231
   Shop #: WSC 02164 790 50316
   ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
   ROD: EV_AirbaVW10BPAVN750.rod
2 Faults Found:
9446677 - Redundant signal path for airbag shut-off; passenger side
          B1025 15 [137] - Open or Short to Plus
          MIL ON - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 86850 km
                    Date: 2020.11.01
                    Time: 15:54:24
9445397 - Key switch for deactivation of passenger-side airbag
          B1020 15 [137] - Open or Short to Plus
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 86850 km
                    Date: 2020.11.01
                    Time: 15:54:24
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb-SRI1
   Part No SW: 7E0 920 970 S    HW: 7E0 920 970 S
   Component: KOMBI         H03 1107
   Serial number: 00000000000000
   Coding: 050B030300
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05733
   ROD: EV_Kombi_UDS_VDD_RM09_005_VW31.rod
   VCID: 3A7B87EFBD5F90561D-806E
Address 19: CAN Gateway (J533)       Labels:. 7E0-909-901.clb
   Part No SW: 7E0 909 901     HW: 7E0 937 090 C
   Component: GW-K-CAN TP20 H82 0752
   Revision: B9082001
   Coding: 042307
   VCID: 68DF0DA79B73D2C6BB-803C
1 Fault Found:
01044 - Control Module Incorrectly Coded
            000 - -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 86850 km
                    Time Indication: 0
                    Date: 2020.11.01
                    Time: 16:00:45
Address 25: Immobilizer (J334)       Labels:| 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H03 1107
   Serial number:
   Coding: 000000
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
   ROD: EV_Immo_UDS_VDD_RM09_VW31.rod
   VCID: 6ADB77AF8D7FE0D6AD-803E
Address 56: Radio
Cannot be reached
Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-STD2.clb
   Part No SW: 5C0 035 680 G    HW: 5C0 035 680 G
   Component: MU-S-ND-ER    H41 0468
   Serial number: VWZAZ2U0686474
   Coding: 06570001AA00000011111101008808001F0100D601200100CF
   Shop #: WSC 03489 004 104857
   ASAM Dataset: EV_MUStd4CTSAT 001022
   ROD: EV_MUStd4CTSAT_VW32.rod
   VCID: 2541449324E10FAE40-8070
4 Faults Found:
0512 - Rear Right Bass Speaker
          B1067 13 [009] - Open Circuit
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 240
                    Mileage: 86850 km
                    Date: 2020.11.01
                    Time: 15:54:24
                    Voltage terminal 30: 11.8 V
0517 - Front Right Bass Speaker
          B1062 13 [009] - Open Circuit
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 240
                    Mileage: 86850 km
                    Date: 2020.11.01
                    Time: 15:54:24
0522 - Front Left Bass Speaker
          B105F 13 [009] - Open Circuit
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 240
                    Mileage: 86850 km
                    Date: 2020.11.01
                    Time: 15:54:24
0527 - Rear Left Bass Speaker
          B1065 13 [009] - Open Circuit
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 240
                    Mileage: 86850 km
                    Date: 2020.11.01
                    Time: 15:54:24
End-------------------------(Elapsed Time: 03:05)--------------------------
thanks
Your CAN gateway is coded incorrectly.
Can you show us your INSTALLED LIST?
Is your camera setup lowline or highline?
I'm wondering why 56-Radio is ticked? It's probably confusing the 19-Gateway?
Although your coding for 10: Park/Steer Assist shouldn't disturb Rear View Camera, I'd still try stripping "extras" off to eliminate coding glitches and try just "plain" 00 00 05 11 11 - which works for me (towbar) or 00 00 05 10 11 (without towbar).
5F coding seems to be ok - byte 19, bit 4 "1"
Oops... Just realized that your BCM has built-in 61-Battery Regulator. Tick 61 on Gateway Installation List. However, not sure if that resolves the Rear View Camera - yet.
Do you get the ABS fault also with "plain" coding of 10: Park/Steer Assist - 00 00 05 11 11
Unfortunately in T6 the fault in 10: Park/Steer Assist won't clear.
See also:
Is your camera brand new or second hand?
Did you get a chance to test it before installation?
I presume your camera is CVBS so you should be able to test it on your TV analogue input.
Hi there, @Robert I have a 2019 Highline Kombi with factory fitted camera. Is it possible to have the moving guidelines and if so what do I need to do ?
Keep watching this space.
Full guidance and part list will be provided as usual :thumbsup:.
Can be problem Because I have short wheelbase camera is long way base?
SWB, LWB makes no difference.
Where did you connect your permanent 12V DC, reversing signal and GND to?
