Yesterday my electric slider (ie it has both slider motor and soft close) refused to work with button blinking. I had OBDeleven with me and got the following code:
I was able to operate the door manually though so not a real issue although the door is pretty heavy to use with motors attached.
Today, I was able to hook up VCDS and got two faults:
I played around with the door and got the motor working, after which I'm left with only 02364 error. The trouble is that when the soft close doesn't play along, the door doesn't close completely. Even if I push the middle door button on dash to cancel out the electrics the door just kind of clunks and I can't push it completely closed.
So... obviously I have contact issues somewhere. The trouble is that when opening motor didn't work yesterday I had no problems opening or closing the door. But now with soft close erring, it's much worse as I could not figure out how to close the door - I only got it closed after trying some tens of times.
I even tried to remove module 78 from installation list to get the entire door electrics disabled for time being but unfortunately the door still seemed to operate on electrics, weird.
It might be a little while until I have a chance to start hunting for the wiring / contact issues. Will report my findings here when I do - meanwhile if anyone has any tips on how to override full electric slider for manual operation I would be grateful!
Code:
Sunday,01,October,2023,17:49:03:11176
VCDS Version Release 23.3.1 (x64) Running on Windows 10 x64(VMWare)
www.Ross-Tech.com
Address 78: Slide Door, Right Labels: Redir Fail!
Control Module Part Number: 7E0 959 243 D
Component and/or Version: Schiebetuer-SG 407 0328
Software Coding:
Work Shop Code: WSC 00000 000 00000
VCID: 303278AAE621E90ABFB-8065
2 Faults Found:
02364 - Closing Assistance
012 - Electrical Fault in Circuit - Intermittent
02363 - Motor for Opening Sliding Door (V293)
004 - No Signal/Communication - Intermittent
