Another power latching problem
jamo1080
Hi, im a long time lurker around here, I’m having issues with my passenger side sliding door and I can’t find a solution to my problem. My t6.1 has dual electric sliding doors with power latching/soft close but the soft close has stopped working on the passenger side. The door opens and closes on the key fob, button on the dash and both handles but it won’t pull in the last bit. I can shut it with a forceful push to get it to close all the way. I’ve gone down a trouble shooting rabbit hole and I’m now a bit stuck.
On the working side, the connector in the B pillar is giving 12v on pin 2, 4ish v on pin one and the same on pin 3. On the side that won’t soft close I’m getting the 4v on pins 1 and 3 but not the 12v on pin 2, it’s a re/blue wire. Before I start stripping the van to try and find out where it goes, does anyone have any advice on whether or not this could be the problem or where to look at first? I switched the modules above the rear wheel arch and the issue was still on the passenger side so presume that’s not the problem. I’ve bought a new power latching motor and that hasn’t fixed it so I’m running out of ideas.
Any help would be greatly appreciated.
Just in case anyone else has the same problem. I had read that there wasn’t separate fuses for the power latching but it turns out there is 2 15amp fuses under the drivers seats. One of which had blown. Fuse changed and all works again. Better than £1500 Vw quoted for the repair.
Blimey. I had mine changed for ~£400 at an independent.
Did you ever get to the bottom of this? I am troubleshooting something similar on a powered/soft close Caravelle
Yes, there is a fuse for the sliding door mechanism on both sides under the drivers seat. One of mine had blown.
Mmm I dont think this is my problem, its all sort of working except the rear latch is not opening, its trying though
I wonder if there is a fuse for the rear soft close as well, mine opens and closes - but the soft close function no longer works
There should be electrical diagrams and fuse layouts on the Forum, available to VIP Members.
I think its the power mech. I can make it do everything but its not pulling the cable to release the rear catch. I have ordered a new one.
I don't believe there is, I searched long and hard for a soft close fuse. VW replaced the module near the rear wheel arch under warranty in the end.
That's what I'm worried about, I've seen another post about those overheating. But I opened up the latch and it was completely rusted up
