I think it's actually "P053A 00 - Crankcase ventilation heater - open circuit". Thus I would first check the fuse (by left headlight: SB3 or SB7, (5 Amps), the latter for EU6 engines) and the wiring to the heater.
Depending on the engine - I'd look along the air pipe from air cleaner box down to turbo. Just before the turbo breather pipe joins the fresh air pipe - the heater is there. Only electric element in the pipe next to turbo. #34 in the picture (single turbo engines CX..).
A related recall in Nordic countries only.
Reference id: 2 1 G 6 Selected T6's based on build date. Breather hose from crankcase to turbocharger air intake will be replaced with a new one which has a redesigned heating element. Possible ice buildup in the hose when intake air is very cold. Ice sucked into turbocharger might cause...
www.t6forum.com
