I have a fault showing on my 2017 T6 Transporter for an intermittent TPMS Fault, This only showed on an auto scan today after i had my tyres swapped yesterday. The TPMS light did come on after the swap however i reset that via the console and it hasn't re illuminated. i have had slightly larger tyres fitted but it was a new set of 4 the same size all round. Would anyone know what this fault would likely relate to any why it wont clear in VCDS?
Fault Code Below.
1 Fault Found:
0397 - TPMS Warning
C102D F0 [008] - Pressure Loss
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 3
Fault Frequency: 2
Reset counter: 19
Mileage: 108294 km
Date: 2024.04.18
Time: 22:55:15
The vehicle is a 2017 VW T6 and im pretty sure that does the TPMS through the ABS sesnsors but im happy to be corrected? is there a way of checking on vcds if one of my wheel sensors isnt working and which wheel it would relate too?
Any help would be greatly appreciated.
Aaron
Full Scan Below
Saturday,20,April,2024,15:06:12:41814
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 23.3.0.0 HEX-V2 CB: 0.4631.4
Data version: 20230228 DS346.1
www.Ross-Tech.com
VIN: xxxxxxxxxxxxx License Plate: 67
Mileage: 108360km-67331mi Repair Order: 004
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 08 09 10 13 15 17 19 25 5F 61 0B
VIN: WV1ZZZ Mileage: 108360km-67331miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
Address 01: Engine (2D2D2-CXHA) Labels:. 04L-907-309-V2.clb
Part No SW: 04L 906 056 KL HW: 04L 907 445
Component: R4 2.0l TDI H02 3802
Revision: 23002001
Coding: 00194014432401090000
Shop #: WSC 02739 790 50316
ASAM Dataset: EV_ECM20TDI03004L906056KL 004003
ROD: EV_ECM20TDI03004L906056KA.rod
VCID: 015F89C7E1833F6200D-8054
VINID: 9E606AAAA1D8A9A6001062040434D5ABEB
No fault code found.
Readiness: N/A
Address 03: ABS Brakes (J104) Labels: 7E0-907-37x-MK100ESC.clb
Part No SW: 7E0 907 379 P HW: 7E0 907 379 M
Component: ESC H06 0133
Revision: 00000000 Serial number: 62327000000592
Coding: 307E4098656684840C7D027AA68321D379F100
ASAM Dataset: EV_Brake1ESCCONTIVN75XGP2 011001
ROD: EV_Brake1ESCCONTIVN75XGP2_011.rod
VCID: 3FDB4F3FD7F78992369-806A
1 Fault Found:
0397 - TPMS Warning
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 19
Mileage: 108294 km
Date: 2024.04.18
Time: 22:55:15
Address 04: Steering Angle (G085) Labels:* 6R0-959-654.clb
Part No SW: 6R0 959 654 HW: 6R0 959 654
Component: LENKW.SENSOR H07 0070
Serial number: 17081713470972
Coding: 01
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_LWSKLOVW25X 005001
ROD: EV_LWSKLOVW25X.rod
VCID: 7EA5F23B907D409A7DF-802A
Address 08: Auto HVAC (J301) Labels:| 7E5-907-047.clb
Part No SW: 7E0 907 047 AJ HW: 7E0 907 047 AJ
Component: Climatic-T5 H22 0708
Revision: 00001002
Coding: 0000000003
ASAM Dataset: EV_ClimaticT5 A01003
ROD: EV_ClimaT5Basis.rod
VCID: 72BDD60BD42514FA097-8026
Address 09: Cent. Elect. (J519) Labels:. 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 C HW: 7E0 937 090 C
Component: BCM PQ25 Max4 H82 0752
Revision: B9082001 Serial number: 4000 230171725
Coding: A0FC793A0A61341393284F646CEB8EF40D84718960CC6D603304003F0840
Shop #: WSC 02739 534 268957
VCID: 2B030B6F330F05328A1-807E
Subsystem 1 - Part No: 5K7 955 559 C Labels: 5K7-955-559.CLB
Component: RLS 210817 04 42 0106
Coding: 0228EE
Subsystem 2 - Part No SW: 7E0 959 801 R HW: 7E0 959 801 R Labels: 7E0-959-80X-V2.CLB
Component: J386__TSG_FT 004 0653
Serial number: KU0KU014081772261324
Coding: 1400B1
Subsystem 3 - Part No SW: 7E0 959 802 Q HW: 7E0 959 802 Q Labels: 7E0-959-80X-V2.CLB
Component: J387__TSG_BT 003 0653
Serial number: KU0KU014081772262868
Coding: 0400A1
Subsystem 4 - Part No: 7E1 951 172
Component: DWA-Sensor 00 001 0104
Coding: 000000
Subsystem 5 - Part No: 1K0 951 605 F
Component: LIN BACKUP HO H01 0008
Coding: 000000
Subsystem 6 - Part No: 7E1 951 172
Coding: 000000
Subsystem 7 - Part No SW: 7E0 959 442 HW: 7E0 959 442 Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H02 0103
Serial number: 39170002155740127321
Coding: B0FFFF
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 AA HW: 7N0 919 475
Component: PARKHILFE 8K H06 0212
Revision: -------- Serial number: 28231716104225
Coding: 10800C
ASAM Dataset: EV_VW75XParkAssis8K 001012
ROD: EV_VW75XParkAssis8K_001_VN75.rod
VCID: 71BFD907D1232FE2F0D-8024
Address 13: Auto Dist. Reg (J428) Labels:| 7N0-907-572.clb
Part No SW: 7N0 907 572 C HW: 7E0 907 572
Component: ACC Bosch PQx H03 0211
Serial number: 1108170453A0FF Dataset Number: 7E0114v____ 0009
Coding: 00004000FE0779
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_ACCBEGVW361 001006
ROD: EV_ACCBEGVW361.rod
VCID: 36352A1BF8CD48DAE5F-8062
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 7E0 959 655 G HW: 7E0 959 655 G
Component: VW10Airbag021 H08 0018
Revision: -------- Serial number: 003V3005XP7L Dataset Number: 7E0003V____ 0905
Coding: 000000000000000000000000000000003231
Shop #: WSC 02734 790 50316
ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 3A2D3E2BCCD5ACBA017-806E
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 7E0 920 970 S HW: 7E0 920 970 S
Component: KOMBI H03 1107
Serial number: 00000000000000
Coding: 740B010300
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05733
ROD: EV_Kombi_UDS_VDD_RM09_005_VW25.rod
Address 19: CAN Gateway (J533) Labels:. 7E0-909-901.clb
Part No SW: 7E0 909 901 HW: 7E0 937 090 C
Component: GW-K-CAN TP20 H82 0752
Revision: B9082001
Coding: 042305
VCID: 6889B463E279EE2AA73-803C
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H03 1107
Serial number:
Coding: 000000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
VCID: 6A8DCE6BFCF5DC3AB17-803E
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD2.clb
Part No SW: 5K7 035 200 K HW: 5K7 035 200 K
Component: MU-S-D-ER H41 0478
Serial number: VWZAZ2T5340599 Dataset Number: V03935266VJ 0001
Coding: 065700003C00000011111101008808001F0100C60020010003
ASAM Dataset: EV_MUStd4CTSAT 001022
ROD: EV_MUStd4CTSAT_VW32.rod
VCID: 2C0108733681020A83B-8078
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 7E0 907 534 HW: 7E0 937 090 C
Component: Batt.regelung H82 0752
Coding: 030B7A73
Shop #: WSC 02739 790 00000
Subsystem 1 - Part No SW: 7E0 915 181 K HW: 7E0 915 181 K
Component: J367-BDMConti H03 1050
Serial number: 75885700001708150D1A
End----------(Elapsed Time: 01:48, VBatt start/end: 12.2V/12.2V)-----------
Address 03: ABS Brakes Labels: 7E0-907-37x-MK100ESC.clb
Control Module Part Number: 7E0 907 379 P HW: 7E0 907 379 M
Component and/or Version: ESC H06 0133
Software Coding: 307E4098656684840C7D027AA68321D379F100
Work Shop Code: WSC 02739 790 50316
ASAM Dataset: EV_Brake1ESCCONTIVN75XGP2 011001 (VN75)
1 Fault Found:
0397 - TPMS Warning
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 19
Mileage: 108294 km
Date: 2024.04.18
Time: 22:55:15
1 Fault Found:
0397 - TPMS Warning
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 19
Mileage: 108294 km
Date: 2024.04.18
Time: 22:55:15
1 Fault Found:
0397 - TPMS Warning
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 19
Mileage: 108294 km
Date: 2024.04.18
Time: 22:55:15
1 Fault Found:
0397 - TPMS Warning
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 19
Mileage: 108294 km
Date: 2024.04.18
Time: 22:55:15
Fault Code Below.
1 Fault Found:
0397 - TPMS Warning
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 19
Mileage: 108294 km
Date: 2024.04.18
Time: 22:55:15
Aaron
Full Scan Below
www.Ross-Tech.com
Revision: 23002001
Readiness: N/A
1 Fault Found:
0397 - TPMS Warning
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 19
Mileage: 108294 km
Date: 2024.04.18
Time: 22:55:15
Coding: 01
Revision: 00001002
Coding: 0000000003
Coding: 0228EE
Coding: 1400B1
Coding: 0400A1
Coding: 000000
Coding: 000000
Coding: 000000
Coding: B0FFFF
Coding: 10800C
Coding: 740B010300
Revision: B9082001
Coding: 042305
Serial number:
Coding: 000000
Coding: 030B7A73
1 Fault Found:
0397 - TPMS Warning
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 19
Mileage: 108294 km
Date: 2024.04.18
Time: 22:55:15
1 Fault Found:
0397 - TPMS Warning
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 19
Mileage: 108294 km
Date: 2024.04.18
Time: 22:55:15
1 Fault Found:
0397 - TPMS Warning
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 19
Mileage: 108294 km
Date: 2024.04.18
Time: 22:55:15
1 Fault Found:
0397 - TPMS Warning
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 19
Mileage: 108294 km
Date: 2024.04.18
Time: 22:55:15
