RENOGY release DC-DC 20/40A charger! . . . . . . . . . .
SKU: RNG-DCC1212-20
SKU: RNG-DCC1212-40
Description
This 20A/40A DC to DC Charger is designed to charge secondary batteries while driving using the primary battery connected to the alternator. It is able to charge: Flooded, Gel, AGM, and Lithium batteries using multi-stage charging.
Key Features
1: I phase (bulk) At the beginning of the charging process, the flat battery is charged with a constant current (100 % charge current) until the battery voltage reaches the charging end voltage. The charging current decreases when the battery has reached this charging level.
2: U0 phase (absorption) Now the absorption charging process (U0 phase) begins, where the duration depends on the battery. The voltage remains constant (U0). This phase is limited to a maximum of 3 hours to prevent overcharging the battery while driving.
3: U phase (float) Aer the U0 phase, the battery charger switches to the conservation charging function (U phase).
https://www.renogy.com/template/files/Manuals/Renogy DC-DC Battery Charger Manual.pdf
Renogy 12V DC to DC On-Board Battery Charger
SKU: RNG-DCC1212-20
SKU: RNG-DCC1212-40
Description
Key Features
- Multi-Chemistry Battery Types ( Flooded, Gel, AGM, and Lithium )
- Smart Protection Features ( Battery Isolation, Over-voltage safety, Overheat protection, and Reverse polarity protection)
- S3-phase Charging (Bulk, Boost, and Float)
- Built tough for all conditions
- Able to charge an auxiliary battery to 100% state of charge
- Increases run time of loads, such as fridges and lights
- Overcomes voltage drop caused by long cable runs
- Prolongs Battery Life
