My Air-Con Retrofit thread
In what context - engine coding?
Anyways - Semi-Automatic should be the Climatic (as in your picture above - the same as mine, and the coding below)
So Bidirectional should then be the fancy Climatronic - with digital displays and left/right vent temperatures controlled independently.
How did you reprogram the stop start fitted mine but had stop start error and not working ever since
Stop-start isn't part of A/C. I would guess there is something else wrong. Have you checked for fault codes in engine?
Hi,
I have started collecting parts to retrofit air con to my van. Has this been successfully completed by anyone? I see it is commonly done on T5s but only an aftermarket kit is fitted by Alpinair to the T6.
Does anyone know of any other parts required or have any wiring diagrams etc?
Thank you.
Hi mate would you consider doing the same conversion for me ,I have a full genuine ac kit from transporter heaven with full loom if your interested let me know 🙏🏻🙏🏻🙏🏻🙏🏻
