I don't understand!Have replaced immediately with the same Continental Conti 200 - was able to bring this this to the hard shoulder calmly - glad they were commercial rated. For those thinking of not using C tyres!!
I understood his comment as meaning that the stiffer sidewall on the commercial tyre gave some degree of control to bring it to a stop.I don't understand!
Having commercial tyres didn't prevent this from happening and when that tyre went "pop" it would have made no difference to the outcome, you were running on a completely deflated tyre until you could get to a safe place to stop.
There’s another hole there lol
Are you saying that a 'commercial rated' tyre is different to a correctly load rated tyre for the vehicle?
Yes the two holes indicates that I hit something but motorway was clear I heard nothing. Must have done though.
I very much doubt that.
If like me and others you probably notice tramlines in the road as you run over them so for you to hit a substantial object and not notice is unrealistic.
Substantial because it would have had to have be several inches high to cause that damage on the sidewall.
Without a physical examination of the tyre I’m pretty confident that it’s old, probably kerb, damage that has finally given way.
Your tyres sidewalls are put under enormous stress and often heat from under inflation or heavy loads. As I’ve said before on here elsewhere, as tyres rotate the sidewalls flex from relaxed to bulging, hundreds of times a minute. The heat generated has catastrophic effect on the carcass and if there is a weakness it’ll eventually show up.
maybe - I never proclaimed to be a tyre expert and just quoted the RAC.
Point is, I’d rather have the stronger commercial tyres than risk anything else of the same size.
When that tyre totally deflated in a split second, which the damage indicates, a stiffer sidewall of a commercial tyre would make not one jot of difference in terms of control bringing it to a stop, IMHO.I understood his comment as meaning that the stiffer sidewall on the commercial tyre gave some degree of control to bring it to a stop.
the correct 2 part van bolts
