Please post "Detailed ECU info"-report (under Carista Service menu)whether mine's a courier version
Will do tomorrow.Please post "Detailed ECU info"-report (under Carista Service menu)
DETAILED ECU INFO
ECU info obtained with Carista 633099 for iOS:
VIN: WV1ZZZ7HZGH139578
Engine
Part #: 03L906019GQ
Component: R4 2,0L EDC
Software version: 8440
ASAM/ODX identifier: EV_ECM20TDI01103L906019GQ
Coding: 01194012230401080000 (hex)
Fault codes:
05273 Manufacturer-specific code
05459 Manufacturer-specific code
ABS
Part #: 7E0907379P
Component: ESC
Software version: 0132
ASAM/ODX identifier: EV_Brake1ESCCONTIVN75XGP2
Coding: 557E409825658487AA7A027DA48A21E6390000 (hex)
[No fault codes]
Instrument cluster
Part #: 7E0920960L
Component: KOMBI
Software version: 1007
ASAM/ODX identifier: EV_Kombi_UDS_VDD_RM09
Coding: 470B010100 (hex)
[No fault codes]
Airbags
Part #: 7E0959655G
Component: VW10Airbag01N
Software version: 0018
ASAM/ODX identifier: EV_AirbaVW10BPAVW12X
Coding: 00000000000000000000000000000000314E (hex)
[No fault codes]
Steering angle
Part #: 6R0959654
Component: LENKW.SENSOR
Software version: 0070
ASAM/ODX identifier: EV_LWSKLOVW25X
Coding: 01 (hex)
[No fault codes]
Heater & air conditioning
Part #: 7E0907047AK
Component: Climatic-T5
Software version: 0708
ASAM/ODX identifier: EV_ClimaticT5
Coding: 0000000003 (hex)
[No fault codes]
Central electronics
Part #: 7E0937090
Component: BCM PQ25 Max4
Software version: 0736
ASAM/ODX identifier: [none]
Coding: A0A4393A0A613491922049746C2B8C548F20710F60CE4D60320400230800 (hex)
Fault codes:
03303 Feedback Locked-Position rear-left
CAN network gateway
Part #: 7E0909901
Component: GW-K-CAN TP20
Coding: 042305 (hex)
[No fault codes]
Immobilizer
Part #: 5K0953234
Component: IMMO
ASAM/ODX identifier: EV_Immo_UDS_VDD_RM09
Coding: 000000 (hex)
[No fault codes]
Battery regulator
Part #: 7E0907534
Component: Batt.regelung
Coding: 030B1A73 (hex)
[No fault codes]
Infotainment system
Part #: 1K8035150E
Component: MU-E-D-ER
Software version: 6495
ASAM/ODX identifier: EV_MUEnt4CGen2LGE
Coding: 065700003C00000041111101008000001F0002860000010001 (hex)
Fault codes:
00003 Control Module
00011 Manufacturer-specific code
Obtained with Carista 633099 for iOS.
Download app: Carista OBD2
Facebook: Carista
Thanks!Here you go, @mmi . Thank you for this.
Yes, correct. It's CAAC engine (been around since 2010, well provenThanks @mmi . After about an hour searching for the ERG pipe (long story), I suspect my engine is the 5.1 engine that was carried over into early 2016s. Looks nothing like the standard T6 engine and a lot like the 5.1. Build was Aug 16. Might explain why mine behaves differently to the OP.
Curious to see if the engine has the same software as in EU. Could you please post "Detailed ECU info"-report (under Carista Service menu).Mine is a CAAC engine, no AdBlue but delivered Nov 2019. I understand Aus got Euro5 engines later than anywhere else due to our lax emissions laws
Detailed ECU info below.Curious to see if the engine has the same software as in EU. Could you please post "Detailed ECU info"-report (under Carista Service menu).
DETAILED ECU INFO
ECU info obtained with Carista 403099 for iOS:
VIN: WV1ZZZ7HZKH102968
Engine
Part #: 03L906019JP
Component: R4 2.0l TDI
Coding: 01254012233401080000 (hex)
[No fault codes]
Transmission
Part #: 0BT300046G
Component: DSG DQ500-7F
Coding: 0014 (hex)
[No fault codes]
ABS
Part #: 7E0907379P
Component: ESC
Coding: 557E409825628480AA7E027CA48A21E6390000 (hex) [No fault codes]
Instrument cluster
Part #: 7E0920871A
Component: KOMBI
Coding: 140B010100 (hex)
[No fault codes]
Airbags
Part #: 7E0959655K
Component: VW10Airbag01J
Coding: 00000000000000000000000000000000314A (hex) [No fault codes]
Steering angle
Part #: 6R0959654
Coding: 01 (hex)
[No fault codes]
Parking/steering assist
Part #: 7E0919475T
Component: PARKHILFE 4K
Coding: 318108 (hex)
[No fault codes]
Part #: 7E0907047AJ
[No fault codes]
Trailer
Part #: 1K0907383H
Component: Anhaenger
Coding: 430D000100000000 (hex)
[No fault codes]
Central electronics
Part #: 7E0937090D
Coding: 62A8393A2A21201101280F742EEB8ED48F88710F60446DE0330400230800 (hex) Fault codes:
00979 Lamp for Low Beam; Right (M31)
CAN network gateway
Part #: 7E0909901
[No fault codes]
Immobilizer
Part #: 5K0953234
Component: IMMO
Coding: 000002 (hex)
[No fault codes]
Battery regulator
Part #: 7E0907534
Coding: 330B7A73 (hex)
[No fault codes]
Infotainment system
Part #: 1K8035150G
Component: MU-E--ER
Coding: 065700003C00000041510001000000001F0000D60000010001 (hex) [No fault codes]
Obtained with Carista 403099 for iOS.
Facebook: Carista
Thank you. The main revision of engine's software family 03L906019JP is the same as was used in Europe. However, interestingly Carista's IOS version has stripped off the exact version number. I was hoping to see an additional line: Software version in the log.Detailed ECU info below.
DETAILED ECU INFO
Engine
Part #: 03L906019JP
[No fault codes]
I did the scan again using the current Carista version (the info I posted was from an earlier version soon after I bought the van).Thank you. The main revision of engine's software family 03L906019JP is the same as was used in Europe. However, interestingly Carista's IOS version has stripped off the exact version number. I was hoping to see an additional line: Software version in the log.
E.g.
Part #: 03L906019JPComponent: R4 2,0L EDCSoftware version: 8439ASAM/ODX identifier: EV_ECM20TDI01103L906019JPCoding: 01254012232401080000 (hex)
The above is a snippet from below (Carista Android)
EML mass air flow fault 04795 [Resolved]
Hello all my engine management light came on I plugged Cristia in and come up with fault mass air flow so changed to new pattern part one to see if issue drove all about 40 miles and back on any help idea pleasewww.t6forum.com
For the engine software 03L906019JP (at least) the following versions exist: 8439, 9977, 9978.
Thanks. Yes, it's the latest versionI did the scan again using the current Carista version (the info I posted was from an earlier version soon after I bought the van).
Engine
Part #: 03L906019JP
Software version: 9978
So it has the latest version - 9978?
cheers
