OkCześć.
Please watch the whole video and post here your AUTOSCAN as a text(not as a photo).
so will it be ok?Log-ROGALAWV-WVGZZZ5NZHW876198-176190km-jarek.txt
drive.google.com
Doesn't work for me!so will it be ok?
Unfortunately @jarek you still didn't watch this video.Cześć.
I watched it and did the same thingUnfortunately @jarek you still didn't watch this video.
It takes less than 5 minutes of your time.
Please do as it explains in plain format the whole process of gathering required data and then process of posting it in the forum.
that link should now work
Adres 18: Ogrzew.pomocn. (J364) Plik etykiet:| 5Q0-963-272.clb
Oznaczenie elementu SW: 5Q0 963 272 G HW: 5Q0 963 272 G
Komponent: STH-MQB 008 0075
Kodowanie: 9309
Kod serwisu: WSC 01357 011 00200
Zbiór danych ASAM: EV_AuxilParkiHeateWOS 002018
ROD: EV_AuxilParkiHeateWOS_VW37.rod
VCID: 3A7B84EBBD5F9C969F-806E
Zdalne sterowanie radiowe ogrzewania postojowego:
Podsystem 1 - Oznaczenie elementu SW: 3Q0 963 513 HW: 3Q0 963 513
Komponent: R64 D208L 004 0401
Numer seryjny: 00000000000000151137
Nie znaleziono b³êdów.
problem solved... it turned out that the original remote control was damaged and the new one I bought had the wrong code and could not communicate with the control unit. after buying another remote control that communicates with this control unit, everything works!Apologies - this just slipped unnoticed...
Everything looks ok.Code:------------------------------------------------------------------------------- Adres 18: Ogrzew.pomocn. (J364) Plik etykiet:| 5Q0-963-272.clb Oznaczenie elementu SW: 5Q0 963 272 G HW: 5Q0 963 272 G Komponent: STH-MQB 008 0075 Kodowanie: 9309 Kod serwisu: WSC 01357 011 00200 Zbiór danych ASAM: EV_AuxilParkiHeateWOS 002018 ROD: EV_AuxilParkiHeateWOS_VW37.rod VCID: 3A7B84EBBD5F9C969F-806E Zdalne sterowanie radiowe ogrzewania postojowego: Podsystem 1 - Oznaczenie elementu SW: 3Q0 963 513 HW: 3Q0 963 513 Komponent: R64 D208L 004 0401 Numer seryjny: 00000000000000151137 Nie znaleziono b³êdów. -------------------------------------------------------------------------------
Thanks for letting us know the outcome.the new one I bought had the wrong code and could not communicate with the control unit.
if it is heating the engine aw well? Could anybody explain how can I check it?
No, per the coding it does not heat the engine, only the cabin. See post #1.Long Coding: 4D01
Byte 0 in your coding 4D would be as belowLong Coding: 4D01
There should be a sticker on driver door.And how can I check which name of device is installed (is it webasto, thermo top, air top, z/c ...)?
is the Webasto Thermo Top Evo.VAG Part number: 7E0963272B
Change the coding from 4D 01 to coding 49 01 to enable engine heating as well.
Anyways,
The heater starts at any temperature when using a remote. However,I can’t get it to start up.
Does it still have to meet the normal conditions for the heater to start (being 5c or less)?
Yes, it's a specific software which has the parking heater functionality and can be started via a remote.Or do I need to change the software in the unit.
Address 18: Aux. Heat (J364) Labels:| 7E0-963-27X-18.clb
Part No SW: 7E0 963 273 HW: 7E0 963 273
Component: STH-T5GP2 002 0007
Coding: 4101
Shop #: WSC 02759 790 50316
ASAM Dataset: EV_AuxilParkiHeateWOST5G2 001010
ROD: EV_AuxilParkiHeateWOST5G2.rod
VCID: 6ADB74A98D7FEE1A6B-803E
Control Module Part Number: 7E0 963 273
Component and/or Version: STH-T5GP2 002 0007
Software Coding: 4101
Work Shop Code: WSC 02759...
