Looks good....
Add long as there is sufficient fresh air flow..IE is not in a box... Or the heat soak will build up.
So make sure you have vents for air to circulate to the rest of the van...
Once fitted start burn testing it.....
Run it at 25% for 15 mins and monitor the inverter, cables, fuses, connections for temp.
Then try 50%
Then try 75%
Then try 100%
If any thing is wrong or get too hot, then sorry that it.
The final test should be run out at full load for 45 mins, or as long as the max time they systems might run for.
I'm not a fan of over loading inverters, but if you wanted to you could try an overload to spec ..
IE 120% for 30mins
150% for 2mins.
Keeps us posted.
