Thank you very much @Dellmassive - using all this info
It's really difficult to get a handle on the power consumption on this thread, but I caught a stat of a compressor coolbox, with a jacket, taking only 20Ah over 3 days if left unopened?
So, on a more van-centric note, how do top-loading built-in compressor fridge compare? Do they benefit from being built in for the equivalent of a jacket, or could they?
The sums I'm trying to do, like everyone, is the size of battery vs fridge vs solar. How many watts of energy via solar during the day do I need to give the battery enough to power the compressor fridge all day and all night? and be net zero loss of battery health in the morning?
Thanks, what about this one for similar price: https://www.amazon.co.uk/dp/B08J3RW85M/ref=cm_sw_r_cp_awdb_imm_W1BK6KVXZ5PZ04YWXGA6?psc=1led lighting strings.. these draw around 0.5 per string . . . 1ah for two strings, 2ah for 4x strings (when on and running)
you can see that here: https://www.t6forum.com/threads/flag-poles-and-fairy-lights-how-i-done-it.21232/post-289549
loads on power here over at the full thread:
Flag Poles and Fairy lights -- "how I Done It" --
Flag Poles and Fairy lights -- "how I Done It" -- Its that time of year again, suns out, weathers warm, beer is cold - its festival time =] well for us any excuse to have a get together or party . . . This time we look at Flag poles and Fairy lights. My first attempt at Camp lighting...www.t6forum.com
USB chargers. . . are usual 2:1 due to the 50% drop in voltage from 12vdc to 5vdc USB, so 1Amp@12v will give roughly 2A@5v USB. (or 2ah when charging)
we use this style now as we always have loads of USB stuff to keep charged . . .
USB Car Charger, 6 USB Multi Ports Car Charger Adapter, 50W Rapid Car Charger with ISmart USB Hub Compatible with iPhone, iPad, Samsung and Othter USB Device: Amazon.co.uk: Electronics & Photo
Free delivery and returns on eligible orders. Buy USB Car Charger, 6 USB Multi Ports Car Charger Adapter, 50W Rapid Car Charger with ISmart USB Hub Compatible with iPhone, iPad, Samsung and Othter USB Device at Amazon UK.amzn.to
we have one of these too . . .
Car Charger 4-Port QC3.0 RAVPower Quick Charge 3.0 54W: Amazon.co.uk: Electronics
Free delivery and returns on eligible orders. Buy Car Charger 4-Port QC3.0 RAVPower Quick Charge 3.0 54W Car Adapter with iSmart 2.0 Tech, Fast Charge Galaxy S10+ S9+ S8+ Note 10+ Note 9+ Note 8, Compatible with iPhone 11 Pro Max X XR XS Max and More at Amazon UK.amzn.to
That one is epic . . . . . . . !Thanks, what about this one for similar price: https://www.amazon.co.uk/dp/B08J3RW85M/ref=cm_sw_r_cp_awdb_imm_W1BK6KVXZ5PZ04YWXGA6?psc=1
- i think 150w to 300w is the sweet spot . . . . 200w is bang on.That's really useful and neat calculations. Sounds like a 100W solar relies on a big battery. I was erring towards 200W and it sounds sensible now.
- havent got one to test personally . . . . but I'm led to believe they have the same compressor tech as the portable units . . . so power usage should be comparable? (specific unit data to be supplied so we can run the numbers, just like above)But how about built-in fridges?
Okay, how about:- havent got one to test personally . . . . but I'm led to believe they have the same compressor tech as the portable units . . . so power usage should be comparable? (specific unit data to be supplied so we can run the numbers, just like above)
The PSU is mains but not the input, will look again.. Yeah, 12V 5A power
Okay, how about:
Dometic Waeco Coolmatic CB40 Top Loading Compressor Refrigerator
Technical Specifications:
Dimensions:H660 x W300 x D500 mm
Total Capacity:40 Litres
Voltage:12/24 volts DC
Temperature Range:+10°C to -12°C
Power Input:approx. 45 watts
CB40 Refrigerator Current Consumption:0.64 Ah/h at +20°C ambient temperature, 1.01 Ah/h at +32°C ambient temperature, both at +5°C interior temperature
Insulation: PU foam all around
CB40 Refrigerator System:Fully hermetic compressor with integrated control electronics, electronic thermostat, low voltage protection / electronic fuse, automatic reverse pole protection
Material:
Outside: zinc coated sheet steel
Inside: stainless steel
Base: plasticColour:grey/pale grey
Weight:approx. 20.0 kg
nice . .It's a little off topic, but since you are talking about consumption, I have found that the LED tape on a PWM controller seems to use a LOT less power when on 30% PWM, yet the light output does not seem much less.
In practice, this means we always use the lights on 30% PWM for general use, and may just up the cooking area light to full while cooking.
So for 3m total of led strip (rated 3.6W/M) we draw 0.35A on normal (33% PWM) use, and 1.1A on full power.
And on fridges, in the last year our 50L vitrifrigo has ran constantly, there were only a couple of occasions, during the grey/warmish months, when we needed the EHU on, our panel is 160W. During summer camping, the battery was always back up to 100% by lunchtime.
48L / £900 . . . so thats £18.75 per Ltr as a price comp.
@Dellmassive I know you always give everyone advice on every option which is great info (keep it up if you can ), what are your personal thoughts on this Vs cheaper models (I also know you have one of each )!
I've got both, as you say. . . . and to be honest they perform the same.
i had them both running all over xmas for almost 3months flat out at -22degC - no issues with either.
both run floorlessly 24/7 for 3months.
I like having the "brand name" for bragging rights , and it keeps its re-sell value . . . but that's about it.
you could argue there is a slightly better build quality . . . . that's true, but both still function the same.
so if you can afford a brand name and cant sleep at night without having the supposed best bit of kit - then just get it.
if your on a budget and just want the job done, then get a clone machine, put all the money you have saved into another item . . . . .
at current rates you could get two clone machines for the price of one branded version.
Hi @Dellmassive as far as I can see the Dometic CFX3 has only 1 compartment inside. Is that right? Do any of the other makes have just one compartment? Somehow I think that would make it easier for getting more stuff in. Thanks very muchI've got both, as you say. . . . and to be honest they perform the same.
