So, here is my storry
after almost 8 years , when I first time found that EPB - to be honest - I was the first ,
fially I made it in my 21 years old Touran
Thank You
@Robert and
@dnoermann for supporting me , seems "master is asking a student"
here is little pictures:
1) My brake calipers from Q3 2016
Visit this link to download: IMG_20251227_103553
files.fm
2) Rear disc is 300mm from Sharan
Visit this link to download: IMG_20251227_094902
files.fm
Visit this link to download: IMG_20251227_094907
files.fm
Visit this link to download: IMG_20251227_094904
files.fm
3) new brake pipes
Store, share, publish and manage files, photos and videos in one secure EU-based platform.
files.fm
4) New brake disc shield
Visit this link to download: IMG_20251227_094555
files.fm
Visit this link to download: IMG_20251227_094558
files.fm
5) new brake pads
6) 2,5mm2 silicone cable , is going into the metal pipe when hand brake steel rope is going
so "half way" is still factory
Visit this link to download: IMG-20251227-WA0000
files.fm
I remeber that 8 yesr ago I was more struggling due to swich installation
Mechanical or electrical is easy , but comsetis / interiour is the most important , that is why my project was frozzen for a long time
Sharan EPB swich was too big for me
so I was start with Audi 8K, smaller, but not flat
fianlly Q3 8U was the one I install and look qool
Visit this link to download: IMG-20260102-WA0010
files.fm
Visit this link to download: IMG-20260102-WA0012
files.fm
Visit this link to download: IMG-20260104-WA0011
files.fm
Visit this link to download: IMG-20260104-WA0013
files.fm
but I start t o fit it w/o test and after days I realise is not compatybile with 56D EPB module
MQB swich is ok, but too big for my swich frame was made, so failed too
so I strip down one switch competly to make my own diagram , to see what is need to operate EPB
and look like is very simpel diagram, exactly like ELSA show , but that must be confirm first
here is a simple connection diagram with 2 x ALPS SPVQ9 switch and 4 x diodes typical such as 1N4001 with direction as is show
Visit this link to download: IMG-20260111-WA0000
files.fm
when that was ready, I decide to make my own PCB to install into Q3 EPB parking swich
Visit this link to download: IMG-20260110-WA0006
files.fm
Visit this link to download: IMG-20260110-WA0015
files.fm
Visit this link to download: IMG_20260111_094249
files.fm
Visit this link to download: IMG_20260203_151259
files.fm
To eliminate (P) indicator control over NEGATIVE signal , I did changes on my own PCB switch , so hand brake is ON my cluster show (P)
when YELLOW led in switch flashing due to failtrue for example , my cluster (P) also flashing
One important thinks
EPB EEPROM RESET function almost kill my EPB
almost - because still working but with Bassic settings error ,and that couldt be do
so - DONT TRY THIS function at ALL
got a eeprom from other module and problem gone
also durring this time to fix bassic settings error, I strip down 5 other EPB
8K, 4K audi -DONT BUY it , it look this same, but inside CPU is not this same . so even for donor parts is crap
VOLVO S60 31341542 , also crap for VAG another CPU type
the only one good is Range Rover Evoque BJ32 2c496 AH EPB module
but must be strip down and r/w memory
2nd hand module is not much less that factory 56D, so is no point too
soon need to fix my ECU data so EPB can be operate automaticly , so whole "buton" project will go away
