Hello all
I have recently retrofitted an electric sliding door for a friend, everything works fine and no fault codes
only the dash button is not opening the door, when trying to open the door from the button the latch opens to release the door, but the door won't open
i realize that the lock cylinder wont release the door
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
0D-Slide Door, Left -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
78-Slide Door, Right -- Status: OK 0000
Address 01: Engine (J623-CFCA) Labels:. 03L-906-022-CFC.clb
Part No SW: 03L 906 022 JE HW: 03L 907 309 H
Component: R4 2,0L EDC X28 7054
Revision: 22X28--- Serial number: 00000000000000 CVN: 9BB050DD
Coding: 01254012230600080000
Shop #: WSC 92521 052 00000
ASAM Dataset: EV_ECM20BTD01103L906022JE 002005
ROD: EV_ECM20BTD01103L906022JD_002.rod
VCID: F1B438D3A12C0A52F05-80A4
VINID: 9E60AAAAA1D8A926000440C51441B33ED7
No fault code found.
Readiness: 0 0 0 0 1
Address 02: Auto Trans (J743) Labels:. 0BH-927-711.clb
Part No SW: 0BT 300 011 S HW: 0BH 927 711 C
Component: DSG DQ500-7A H04 5202
Revision: 00H04V01 CVN: BEFE9553
Coding: 0014
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_TCMDQ500021 001001
ROD: EV_TCMDQ500021.rod
VCID: BE2ED3EFA0F2A52A3D7-80EA
Address 03: ABS Brakes (-----) Labels: 7E0-907-37x-MK25AXT.clb
Part No SW: 7E0 907 379 F HW: 7E0 907 379 E
Component: ESP MK25A XT H43 0104
Revision: 00H43001
Coding: 108764AD11A5089926A588766A6316
Shop #: WSC 02756 790 49152
VCID: B53CCCC395446672ECD-80E0
Address 08: Auto HVAC (J255) Labels:| 7E5-907-040.clb
Part No SW: 7E5 907 040 H HW: 7E5 907 040 H
Component: ClimatronicT5 H10 0101
Revision: 00002001
Coding: 0002001102
Shop #: WSC 02757 790 50316
ASAM Dataset: EV_ClimatronicT5 A01002
ROD: EV_ClimaAutoT5Basis_VN75.rod
VCID: AD0CE4A37D942EB294D-80F8
Slave 1:
2 Faults Found:
9474065 - Motor for Defroster Flap
B1090 11 [00001001] - Short to Ground
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 205
Mileage: 139131 km
Date: 2025.06.22.
Time: 01:49:04
9480753 - Control/Display Unit for Rear Climatronic
B10AA 31 [00001001] - No Signal
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 205
Mileage: 139131 km
Date: 2025.06.22.
Time: 01:48:29
Address 09: Cent. Elect. (J519) Labels:. 7H0-937-08x-09.clb
Part No SW: 7H0 937 087 D HW: 7H0 937 087
Component: BCM T5GP H+4 H47 0221
Revision: BO047001 Serial number: 0347 176100898
Coding: A1FE793A0E212012002800003C2B8DD40000410F60044000300002000000
Shop #: WSC 02754 790 12345
Subsystem 1 - Part No SW: 7E0 959 801 HW: 7E0 959 801 Labels: 7E0-959-80X-V1.CLB
Component: J386__TSG_FT 002 3311
Serial number: --------------------
Coding: 000000
Subsystem 2 - Part No SW: 7E0 959 802 HW: 7E0 959 802 Labels: 7E0-959-80X-V1.CLB
Component: J387__TSG_BT 002 3311
Coding: 000000
Subsystem 3 - Part No SW: 5TA 959 442 A HW: 5TA 959 442 A
Component: E221__MFL-TAT H06 0023
Serial number: 0191814474430625AO3B
Coding: 280000
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 7E0 959 655 B HW: 7E0 959 655 B
Component: VW10Airbag003 H05 0013
Revision: -------- Serial number: 003HL000JV8D Dataset Number: 7E0003v____ 0465
Coding: 000000000000000000000000000000003033
Shop #: WSC 02754 790 50316
ASAM Dataset: EV_AirbaVW10BPAVN750 A01026
ROD: EV_AirbaVW10BPAVN750.rod
VCID: B53CCCC395C46672ECD-80E0
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 7E0 920 870 C HW: 7E0 920 870 C
Component: KOMBI H04 0204
Coding: 160D00
Shop #: WSC 02756 790 50316
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04086
ROD: EV_Kombi_UDS_VDD_RM09_004_VW32.rod
VCID: A90410B3497C3292785-80FC
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 7H0 937 087
Component: GW-K-CAN TP20 0221
Coding: 042200
VCID: F0B23DD7AAA6035AFFB-80A4
Address 22: AWD Labels: 0AY-907-554-V1.clb
Part No SW: 09N 907 554 A HW: 09N 907 554 A
Component: Haldex 4Motion 6007
Coding: 0000001
Shop #: WSC 02756 790 00000
VCID: B63ECBCF84426D6AE57-80E2
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H04 0204
Serial number:
Coding: 000000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
ROD: EV_Immo_UDS_VDD_RM09_VW32.rod
VCID: EA862FBF8CFAF98AB1F-80BE
Address 56: Radio (J0503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 5K0 035 190 HW: 5K0 035 190
Component: Radio RCD510 041 0167
Revision: 00000001 Serial number: VWZ1Z3K4683803
Coding: 0100040004
Shop #: WSC 00020 790 00000
VCID: E296479F744AA1CA79F-80B6
5 Faults Found:
00872 - Bass Speaker Rear Left (R15)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 205
Mileage: 139131 km
Time Indication: 0
Date: 2019.11.13.
Time: 01:48:41
00873 - Bass Speaker Rear Right (R17)
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 205
Mileage: 139131 km
Time Indication: 0
Date: 2019.11.13.
Time: 01:48:41
00876 - Treble Speaker Rear Left (R14)
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 205
Mileage: 139131 km
Time Indication: 0
Date: 2019.11.13.
Time: 01:48:33
00877 - Treble Speaker Rear Right (R16)
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 205
Mileage: 139131 km
Time Indication: 0
Date: 2019.11.13.
Time: 01:48:33
00856 - Radio Antenna
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 205
Mileage: 139131 km
Time Indication: 0
Date: 2019.11.13.
Time: 01:48:51
Address 78: Slide Door, Right Labels: Redir Fail!
Part No: 7E0 959 243 D
Component: Schiebetuer-SG 407 0328
VCID: B032FDD76626435ABFB-80E4
End----------(Elapsed Time: 01:38, VBatt start/end: 12.3V/12.3V)-----------
------------------------------7 Faults Found-------------------------------
