I've noticed that my 1x main beam flash doesn't work when my headlight selector switch is set to side lights only position, or when set to AUTO in daylight (which equates to the same thing).
The blue main beam indicator illuminates on the dash when the control stalk is pulled, but lamps in headlight don't turn on.
However, the main beam flash DOES work as normal when the headlight selector switch is set to low beam on (and AUTO during darkness).
It's a bit of a problem on the road during daylight when trying to flash other drivers to pass etc at junctions, so would like to get it sorted.
Anybody else had this issue? My lights are retrofitted factory LEDs and there's a chance I may have incorrectly coded something during installation, but they were installed nearly 4 years ago and pretty sure I would have noticed the issue before now.
I've not got any new error codes in VCDS Autoscan (attached) which adds to the mystery!
Any info/pointers on this issue would be much appreciated - thanks!
Code:
Friday,26,September,2025,11:56:52:15218
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x86
VCDS Version: 25.3.2.0 HEX-V2 CB: 0.4671.4
Data version: 20250822 DS365.0
www.Ross-Tech.com
VIN: WV1ZZZ7HZKH043909 License Plate:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 08 09 10 13 15 17 19 25 55 56 61 0B
VIN: WV1ZZZ7HZKH043909 Mileage: 39400km-24482miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: Not registered 0011
61-Battery Regul. -- Status: OK 0000
Address 01: Engine (2D2D2-CXHA) Labels:. 04L-907-309-V2.clb
Part No SW: 04L 906 056 KL HW: 04L 907 445
Component: R4 2.0l TDI H02 3802
Revision: 23002001
Coding: 00194014432401090000
Shop #: WSC 00012 790 50316
ASAM Dataset: EV_ECM20TDI03004L906056KL 004003
ROD: EV_ECM20TDI03004L906056KA.rod
VCID: 015F8C20F18ABD2281D-8054
VINID: 9E606AAAA1D8A9B600103240243FB0733F
No fault code found.
Readiness: N/A
Address 03: ABS Brakes (J104) Labels: 7E0-907-37x-MK100ESC.clb
Part No SW: 7E0 907 379 P HW: 7E0 907 379 M
Component: ESC H06 0133
Revision: 00000000 Serial number: 62918000002868
Coding: 517E4098256684818A7E0276A48B21E679F100
ASAM Dataset: EV_Brake1ESCCONTIVN75XGP2 011001
ROD: EV_Brake1ESCCONTIVN75XGP2_011.rod
VCID: 3FDB4AD8C7FE0BD2B79-806A
Address 04: Steering Angle (G085) Labels:* 6R0-959-654.clb
Part No SW: 6R0 959 654 HW: 6R0 959 654
Component: LENKW.SENSOR H07 0070
Serial number: 13101813470312
Coding: 01
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_LWSKLOVW25X 005001
ROD: EV_LWSKLOVW25X.rod
VCID: 7EA5F7DC8074C2DAFCF-802A
Address 08: Auto HVAC (J301) Labels:| 7E5-907-047.clb
Part No SW: 7E0 907 047 AK HW: 7E0 907 047 AK
Component: Climatic-T5 H22 0708
Revision: 00001002
Coding: 0000000003
ASAM Dataset: EV_ClimaticT5 A01003
ROD: EV_ClimaT5Basis_VN75.rod
VCID: 73B3D6E8BB369FB2831-8026
Address 09: Cent. Elect. (J519) Labels:. 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 D HW: 7E0 937 090 D
Component: BCM PQ25 Max4 H82 0762
Revision: B9082001 Serial number: 8601 297180548
Coding: A0AC39980A61341193284F347CEB9670D084738F60CD79503304003F0860
Shop #: WSC 01369 210 40505
VCID: 2C010D942608804A02B-8078
Subsystem 1 - Part No: 5K7 955 559 C Labels: 5K7-955-559.CLB
Component: RLS 171018 05 50 0106
Coding: 0228EE
Subsystem 2 - Part No SW: 7E0 959 801 P HW: 7E0 959 801 P Labels: 7E0-959-80X-V2.CLB
Component: J386__TSG_FT 004 0653
Serial number: KU0KU001101882740141
Coding: 1400B0
Subsystem 3 - Part No SW: 7E0 959 802 P HW: 7E0 959 802 P
Component: J387__TSG_BT 004 0653
Serial number: KU0KU019101882921610
Coding: 0400A0
Subsystem 4 - Part No: 7E1 951 172
Component: DWA-Sensor 00 001 0104
Coding: 000000
Subsystem 5 - Part No: 1K0 951 605 F
Component: LIN BACKUP HO H01 0009
Coding: 000000
Subsystem 6 - Part No: 7E1 951 172
Coding: 000000
Subsystem 7 - Part No SW: 7E0 959 442 HW: 7E0 959 442 Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H02 0103
Serial number: 39180001895190098383
Coding: B0FFFF
1 Fault Found:
00979 - Lamp for Low Beam; Right (M31)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 185
Mileage: 39405 km
Time Indication: 0
Date: 2020.02.17.
Time: 10:42:36
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 T HW: 1Q0 919 475
Component: PARKHILFE 4K H03 0212
Revision: -------- Serial number: 32961821504623
Coding: 108008
ASAM Dataset: EV_VW75XParkAssis4K 001013
ROD: EV_VW75XParkAssis4K_001_VN75.rod
VCID: 43D34628AB166F32D31-8016
Address 13: Auto Dist. Reg (J428) Labels:| 7N0-907-572.clb
Part No SW: 7N0 907 572 C HW: 7E0 907 572
Component: ACC Bosch PQx H03 0211
Serial number: 1810180440A810 Dataset Number: 7E0114v____ 0009
Coding: 00004000FE0779
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_ACCBEGVW361 001006
ROD: EV_ACCBEGVW361.rod
VCID: 36352FFCE8C4CA9A64F-8062
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 7E0 959 655 J HW: 7E0 959 655 J
Component: VW10Airbag021 010 0018
Revision: -------- Serial number: 003EK002XBA7 Dataset Number: 7E0003V____ 0905
Coding: 000000000000000000000000000000003231
ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 3D2730D0CDF219C2A55-8068
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 7E0 920 971 A HW: 7E0 920 971 A
Component: KOMBI H02 2030
Serial number: 00000000000000
Coding: 750B010300
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05736
ROD: EV_Kombi_UDS_VDD_RM09_005_VW32.rod
VCID: 290FF480297A9562F9D-807C
Address 19: CAN Gateway (J533) Labels:. 7E0-909-901.clb
Part No SW: 7E0 909 901 HW: 7E0 937 090 D
Component: GW-K-CAN TP20 H82 0762
Revision: B9082001
Coding: 742305
VCID: 6889B184F2706C6A263-803C
1 Fault Found:
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 7
Reset counter: 255
Mileage: 37048 km
Time Indication: 0
Date: 2019.04.09.
Time: 11:12:35
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H02 2030
Serial number:
Coding: 000002
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
ROD: EV_Immo_UDS_VDD_RM09_VW32.rod
VCID: 6A8DCB8CECFC5E7A307-803E
Address 55: Headlight Range (J431) Labels:. 6R0-907-357.clb
Part No SW: 6R0 907 357 C HW: 6R0 907 357 B
Component: AFS-ECU 005 0050
Revision: -------- Serial number: -------------- Dataset Number: V03600027F0 0002
Coding: 0FCE020001000000
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_HeadlRegulVWLWRCC 002006
ROD: EV_HeadlRegulVWLWRCC_VW46.rod
VCID: 3A2D3BCCDCDC2EFA807-806E
Address 56: Radio
Cannot be reached
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 7E0 907 534 HW: 7E0 937 090 D
Component: Batt.regelung H82 0762
Coding: 030B1A73
Shop #: WSC 00012 790 00000
Subsystem 1 - Part No SW: 7E0 915 181 K HW: 7E0 915 181 K
Component: J367-BDMConti H03 1050
Serial number: 75885701001810110093
End----------(Elapsed Time: 01:57, VBatt start/end: 14.9V/13.8V)-----------
------------------------------2 Faults Found-------------------------------
