Fault codes after CCS retrofit
carafantastic2020
Afternoon all, I have finally managed to get CCS retro working on my 2019 Caravelle. I've got faults on the 2 electric door controllers and the passenger side window switch on drivers door isn't operating.
I'm not 100% but I had to remove pin 17 on BCM and splice it into grey and white wire on pin 36.
Pin 17 was a green/blue wire to pin 10 on clock spring plug. I've not got anything in pin 17 now on BCM.
Here's the scan I have just done.
Code:
Saturday,28,March,2026,11:51:37:59141
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x86
VCDS Version: 25.3.2.0  HEX-V2 CB: 0.4701.4
Data version: 20250822 DS365.0
www.Ross-Tech.com
VIN: WV2ZZZ7HZKH064652   License Plate: CX19NMF
Mileage: 153360km-95293mi   Repair Order:
Gateway Installation List:  7E0 909 901
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
0D-Slide Door, Left -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
18-Aux. Heat -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
78-Slide Door, Right -- Status: OK 0000
Saturday,28,March,2026,14:03:12:59141
www.Ross-Tech.com
Chassis Type: 7H-VN75 (7E0)
Scan: 01 02 03 04 08 09 0D 10 13 15 17 18 19 25 5F 61 6D 78 0B
VIN: WV2ZZZ7HZKH064652   Mileage: 153360km-95293miles
01-Engine -- Status: Malfunction 0010
Address 01: Engine (J623-CXFA)       Labels:. 04L-907-309-V2.clb
   Part No SW: 04L 906 056 MB    HW: 04L 907 445
   Component: R4 2.0l TDI   H02 6431
   Revision: 23002001
   Coding: 0025401C432401080000
   Shop #: WSC 00012 790 50316
   ASAM Dataset: EV_ECM20TDI03004L906056MB 004004
   ROD: EV_ECM20TDI03004L906056MB.rod
   VCID: 79AFEB3BF9572292C9D-802C
   VINID: 9E60AAAAA1D8A9B60018418508749ECF01
1 Fault Found:
27277 - System Voltage
          P0562 00 [00100111] - Too Low
          Not Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 153273 km
                    Engine speed: 0.00 /min
                    Normed load value: 0.0 %
                    Vehicle speed: 0 km/h
                    Coolant temperature: 33 °C
                    Intake air temperature: 0 °C
                    Ambient air pressure: 1010 mbar
                    Voltage terminal 30: 11.929 V
                    Unlearning counter according OBD: 40
                    Air mass at air mass meter 1: 0.0 kg/h
                    Standardized air flow ratio: 1.000 counts
                    Exhaust recirc.valve 1 bank 1: posit.feedback - Actual value: 1.80 %
                    Throttl.valve adapt. 1 bank 1: posit feedback - Actual value: 0.00 %
                    Charge air pressure: specified value: 0.002 bar
                    Charge air cooler inlet: pressure sensor 1 bank 1: raw value: 1010 mbar
                    Mean injection quantity: 0 mg/stroke
                    Index of current engine mode: 8
                    Index of next requested engine mode: 7
                    Index of engine target mode: 7
Readiness: N/A
Address 02: Auto Trans (J743)       Labels:. 0BH-927-711.clb
   Part No SW: 0BT 300 046 J    HW: 0BH 927 711 G
   Component: DSG DQ500-7F  H11 5303
   Revision: 00H11V01    CVN: D865F555
   Coding: 0014
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_TCMDQ500021 001001
   ROD: EV_TCMDQ500021.rod
   VCID: 3D273F2BADFFDEB2A55-8068
No fault code found.
Address 03: ABS Brakes (J104)       Labels: 7E0-907-37x-MK100ESC.clb
   Part No SW: 7E0 907 379 P    HW: 7E0 907 379 M
   Component: ESC           H06 0133
   Revision: 00000000    Serial number: 63348000000502
   Coding: 347E4098656884822C7B027BA68421D379F700
   ASAM Dataset: EV_Brake1ESCCONTIVN75XGP2 011001
   ROD: EV_Brake1ESCCONTIVN75XGP2_011.rod
   VCID: 3FDB4523A7F3CCA2B79-806A
Address 04: Steering Angle (G085)       Labels:* 6R0-959-654.clb
   Part No SW: 6R0 959 654     HW: 6R0 959 654
   Component: LENKW.SENSOR  H07 0070
   Serial number: 14052113470650
   Coding: 01
   ASAM Dataset: EV_LWSKLOVW25X 005001
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EA5F827E07905AAFCF-802A
Address 08: Auto HVAC (J255)       Labels:| 7E5-907-040.clb
   Part No SW: 7E0 907 040 AB    HW: 7E0 907 040 AB
   Component: ClimatronicT5 H04 0613
   Revision: 00001K04
   Coding: 0000000103
   ASAM Dataset: EV_ClimatronicT5 A01003
   ROD: EV_ClimaAutoT5Basis_VN75.rod
   VCID: 6393A9536BDBC842F31-8036
   Slave 1:
   Subsystem 1 - Part No SW: 7E5 907 049 C    HW: 7E5 907 049 C
   Component: Heckbedienung  H11 0303
   Serial number: BHB-0010412180015241
Address 09: Cent. Elect. (J519)       Labels:. 7E0-937-BCM-V1.clb
   Part No SW: 7E0 937 090 D    HW: 7E0 937 090 D
   Component: BCM PQ25 Max4 H82 0762
   Revision: B9082001    Serial number: 8601 326180281
   Coding: B8DE793A0A61340393288F646CEB8EF58D84698960CC6960330400BF0840
   Shop #: WSC 01211 210 01254
   VCID: 2C01026F4605473A02B-8078
   Subsystem 1 - Part No: 5K7 955 559 C  Labels: 5K7-955-559.CLB
   Component: RLS 261118 05  50  0106
   Coding: 0228EE
   Subsystem 2 - Part No: 7E1 951 171
   Component: DWA-Sensor 00  001 0104
   Coding: 000000
   Subsystem 3 - Part No: 1K0 951 605 F
   Component: LIN BACKUP HO  H01 0009
   Coding: 000000
   Subsystem 4 - Part No: 7E1 951 171
   Coding: 000000
   Subsystem 5 - Part No SW: 7E0 959 442     HW: 7E0 959 442
   Component: E221__MFL-DC1  H02 0103
   Serial number: 39170003041090028034
   Coding: B00000
4 Faults Found:
03303 - Response Closing Status of Rear Left Door
            008 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 27
                    Mileage: 153367 km
                    Time Indication: 0
                    Date: 2020.08.18.
                    Time: 11:55:04
03304 - Response Closing Status of Rear Right Door
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 27
                    Mileage: 153367 km
                    Time Indication: 0
                    Date: 2020.08.18.
                    Time: 11:55:04
01332 - Door Control Module; Passenger Side (J387)
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 243
                    Mileage: 153366 km
                    Time Indication: 0
                    Date: 2020.08.18.
                    Time: 11:50:19
01331 - Door Control Module; Driver Side (J386)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 243
                    Mileage: 153366 km
                    Time Indication: 0
                    Date: 2020.08.18.
                    Time: 11:50:19
Address 0D: Slide Door, Left        Labels: Redir Fail!
   Part No: 7E0 959 243 D
   Component: Schiebetuer-SG  407 0328
   VCID: 3039161F662D23DA3E3-8064
Address 10: Park/Steer Assist (J446)       Labels:| 7E0-919-475.clb
   Part No SW: 7E0 919 475 AA    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0212
   Revision: --------    Serial number: 28231831203314
   Coding: 308908
   ASAM Dataset: EV_VW75XParkAssis8K 001012
   ROD: EV_VW75XParkAssis8K_001_VN75.rod
   VCID: 71BFD31BA1276AD271D-8024
Address 13: Auto Dist. Reg (J428)       Labels:| 7N0-907-572.clb
   Part No SW: 7N0 907 572 C    HW: 7E0 907 572
   Component: ACC Bosch PQx H03 0211
   Serial number: 0312180442A177 Dataset Number: 7E0114v____ 0009
   Coding: 00005000FE1779
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_ACCBEGVW361 001006
   ROD: EV_ACCBEGVW361.rod
   VCID: 3635200788C90DEA64F-8062
Address 15: Airbags (J234)       Labels:| 5K0-959-655.clb
   Part No SW: 7E0 959 655 K    HW: 7E0 959 655 K
   Component: VW10Airbag01S 010 0018
   Revision: --------    Serial number: 003EM0025SJ7 Dataset Number: 7E0003V____ 0909
   Coding: 000000000000000000000000000000003153
   ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 3E253827A0F9C5AABCF-806A
   Crash sensor for side airbag: driver side:
   Serial number: 3495ZRB405F5IGVANGI/
   Crash sensor for side airbag: passenger side:
   Serial number: 3505ZRB404P5IG7GC1CY
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb-SRI1
   Part No SW: 7E0 920 971 A    HW: 7E0 920 971 A
   Component: KOMBI         H02 2030
   Serial number: 00000000000000
   Coding: 740F010300
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05736
   ROD: EV_Kombi_UDS_VDD_RM09_005_VW32.rod
   VCID: 290FFB7B49775212F9D-807C
Address 18: Aux. Heat (J364)       Labels:| 7E0-963-27X-18.clb
   Part No SW: 7E0 963 273 A    HW: 7E0 963 273 A
   Component: STH-T5GP2     003 0009
   Coding: 4101
   ASAM Dataset: EV_AuxilParkiHeateWOST5G2 001013
   ROD: EV_AuxilParkiHeateWOST5G2.rod
   VCID: 2B030173438B40020B1-807E
Address 19: CAN Gateway (J533)       Labels:. 7E0-909-901.clb
   Part No SW: 7E0 909 901     HW: 7E0 937 090 D
   Component: GW-K-CAN TP20 H82 0762
   Revision: B9082001
   Coding: 042307
   VCID: 6889BE7F927DAB1A263-803C
Address 25: Immobilizer (J334)       Labels:| 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H02 2030
   Serial number:
   Coding: 000002
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
   ROD: EV_Immo_UDS_VDD_RM09_VW32.rod
   VCID: 6A8DC4778CF1990A307-803E
Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-STD2.clb
   Part No SW: 5C0 035 680 G    HW: 5C0 035 680 G
   Component: MU-S-ND-ER    H41 0472
   Serial number: VWZAZ2U1664286 Dataset Number: V03935266VJ 0001
   Coding: 06570001BE00000011111101008808001F0100D6002001004F
   ASAM Dataset: EV_MUStd4CTSAT 001022
   ROD: EV_MUStd4CTSAT_VW32.rod
   VCID: 2517F74B256F7672DD5-8070
   Data carrier:
   Subsystem 1 - Part No SW: 5NA 919 866     HW: -----------
   Component: ECE1 2018/19  --- 1030
   Serial number: --------------------
Address 61: Battery Regul. (J840)       Labels:. 1K0-907-534.clb
   Part No SW: 7E0 907 534     HW: 7E0 937 090 D
   Component: Batt.regelung H82 0762
   Coding: 030B1A73
   Shop #: WSC 80093 222 69422
   Subsystem 1 - Part No SW: 7E0 915 181 K    HW: 7E0 915 181 K
   Component: J367-BDMConti  H03 1050
   Serial number: 7588570100181130139F
Address 6D: Trunk Elect. (J605)       Labels:| 7N0-959-107.clb
   Part No SW: 7E0 959 107 A    HW: 7E0 959 107
   Component: HDSG-Modul    H02 0653
   Revision: 31002002    Serial number: 314801907 Dataset Number: 7E0771V____ 0007
   Coding: 19730D4002
   ASAM Dataset: EV_HDSGVN46T 203001
   ROD: EV_HDSGVN46T.rod
   VCID: 2C01026F4685473A02B-8078
Address 78: Slide Door, Right        Labels: Redir Fail!
End----------(Elapsed Time: 02:08, VBatt start/end: 14.9V/14.8V)-----------
------------------------------5 Faults Found-------------------------------
Well, the door controllers connect to the BCM using LIN bus 2 on pin 17 (white connector).
Yes, but the clock spring is not the only "user" of LIN bus 2 - besides the clock spring also the door controllers use same LIN bus on pin 17.
Should wire clock spring pin 10 directly to BCM pin 36, not move full LIN bus at BCM pin 17.
For complete databus wiring (of B549) see page 6 below
