Yeah no worries send me a pm when you want to meet up and we can arrange something![]()
Hi all - this is my first post on this forum! I'm hoping that someone can point me in the right direction - a mate and I started my T6 conversion yesterday which included fitting rear speakers. I bought a great little kit with everything we needed from Absolut5 so props to him. My question is, is there anyone with VCDS that could help with coding in Cornwall or Southwest to enable front/rear fader??
The forum shop has them nowWhen you connect the rear speakers to the head unit what connectors do you need.
These (junior)
https://www.amazon.co.uk/gp/product...act_title_3?ie=UTF8&psc=1&smid=A1VZVD13EY99Z4
or these (micro)
https://www.amazon.co.uk/gp/product...act_title_5?ie=UTF8&psc=1&smid=A1VZVD13EY99Z4
These (junior)
or these (micro)
Hi @da vid, your converter is right and wrong. When you put speakers on the end of the wires they will play music. However; you will have no fader control over them. You need to make a change within VCDS to enable the rear fader within the head unit. It's really easy to do, so a five minute job for someone who has the kit. Take a look at the forum map and see if there are any yellow dots near you, as this identifies a VCDS user. You may then be able to PM them and arrange something.HI,
New to site , need some info on what to do regarding installing some rear speakers a new T6 Highline.
It has composite media all singing and dancing and I have recently had the interior lined. I ask the installer to put the cables into the rear panels so I could install some speakers ( of my choice) when I wish to, he said that he has connected the speaker cables to the rear of the media system and when I connect the speakers the system will automatically recognise the resistance of the speakers and info would come up on the system regarding rear speakers?
Been on some forums reading about this and it seems as if there's more to it than that, do I need to contact someone with a VCDS unit to activate the rear speaker output??
I am near Leicester so if there's anyone local to me who can help I would be much obliged.
Thanks to all in advance.
Dave N
Have you installed the speakers and connected them to the head unit?Hi its imposible for me to program the fader speakers
anybody can explain me step by step,
the operation is the same
My operation is:
connect vcds cable with latest version 17.1.3
go F5 module
coding
long code helper
and on 5 block select 4 channel, 6 speakers
exit
do it
the message codding accepted is displayed
and exit app
the disconnect the key and wait for 10-15min to enter sleep mode (have tested hours to)
the message code accepted appears but not working
how many time de van is into sleep mode?
Many thanks
Hi guys good news!!!
The mistake is revealed
I upgraded vcs to 17.8 and same result coding accepted but nothing programmed when return to code helper the code wasent changed.
And finally decided to downgrade to version vcs 16.8 and code accepted when go to code helper the code has changed,wait to van go to sleep and voila!!! Fader on
My van works with vcs 16.8 better than 17.1.3 or 17.8.
Many thanks for all your reply and support.
