Brake Pad & Disc change - How I Done It -
Dellmassive
VCDS User
Moderator
T6 Master
After a recent trip to the Dealer for Service and Cambelt job, ( we had the dealers do it as we are in a 2yrs extended warranty ) : Cambelt + Water Pump Replacement - Official guidance
At the time, they advised that the rear pads were 90% worn.
which as we all know is an easy money spinner for them, I'm sure every time I've walked into the dealers they taken one look am me and the van and said "Pads & discs all round -Sir? " without even checking.
anyway we know there game, so i politely declined their offer to do the Pads & Discs at the time and carried on like normal.
in the back of my mind i knew that the front and rear brakes have wear sensors of them, and that these come on when the pads are down to 80/90% - and i hadn't seen any warning yet.
so imagine my surprise when almost two weeks to the day, . . . . . this happened.
that message is triggered form one of the brake pad sensors, there is one on each axel. - its assumed that both side are changed at the same time so they save money and weight by just instaklling two sensors and not four.
OK no big deal, they are obviously due to be changed. were at 52k miles,
and i can see from my records that the pads were changed all-round at 29k miles.
looking over here we can see what's required: Service Parts List - What Goes Where -
Brakes:
Pads:
308mm F Pagid Brake Pad (Front Axle) Product Code: 101441298
340mm F Pagid Pagid Brake Pad (Front Axle)Product Code: 101441868
340mm F Brembo Brembo Brake Pad (Front)Product Code: 10144186A
294mm R Pagid Brake Pad (Rear Axle) Product Code: 101441318
294mm R Brembo Brembo Brake Pad (Rear)Product Code: 10144131A
Discs:
Smaller 308mm Front: Pagid Brake Disc (Front Axle)Product Code: 104441288
larger 340mm front; Pagid Brake Disc (Front Axle)Product Code: 104442118
larger 340mm front Brembo Brembo Brake Disc (Front)Product Code: 10444211A
standard 294mm rears: Pagid Brake Disc (Rear Axle)Product Code: 104441368
standard 294mm rears Brembo Brembo Brake Disc (Rear)Product Code: 10444136A
I run a T32 204 DSG and as such have the Larger 340mm front brakes,
that means i need the :
Now about a year ago, well, two by now . . . i made use of the BLACK FRIDAY sale and procured a full set of BREMBO pads and discs.
I've had them in the garage ever since . . . . . . 4x discs and a full set of pads.
iv already got all the tools to do the job . . so lets that a quick look. . . .
Trolley Jack and axle stands are standard, but there are a few extra bits you need.
you will need a brake calliper wind back tool, i have the kit form as i do other pad jobs.
Brake cleaner is a must . . .
there is the 9mm long bit for the slider guide pin. . . . but i check that fully after.
Then some standard garage hand tools.
I decided to try this new little ProSlip Grease kit highlighted by a fellow T6F member . .
ill be doing the job soon . .
so starting this thread now.
p2
reference material
we have the OEM guides available in the download section.
Fronts : T6 & T6.1 - Brake Pad Replacement
Braking System Workshop Manual​
Rear guide by @Loz - https://www.t6forum.com/threads/how-to-changing-rear-disks-rotors-and-pads.12709/
p3
Torques and settings:
front
- Brake disc Vehicles with 16'' wheels, 2E3. ♦ Ventilated brake disc: ∅ 308 mm. ♦ Brake disc thickness: 29.5 mm. ♦ Wear limit: 26.5 mm.
Vehicles with 17'' wheels, 2E4. ♦ Ventilated brake disc: ∅ 340 mm. ♦ Brake disc thickness: 32.5 mm. ♦ Wear limit: 29.5 mm. ❑
When worn, renew on both sides of axle. ❑ Never remove brake discs from wheel hubby force. If necessary use penetrating fluid, because otherwise brake discs can be damaged.
front
- Brake pads Vehicles with 16'' wheels, 2E3. Brake pad thickness: 12.5 mm not including backplate . Wear limit: 2 mm not including backplate.
Vehicles with 17'' wheels, 2E4. . Brake pad thickness: 11 mm not including backplate . Wear limit: 2 mm not including backplate.
Always replace on both sides ❑ The inner pad on the left side of the vehicle has a wear indicator. ❑ When wear reaches a predetermined limit (maximum 2to 3 mm), brakepad warninglamp - K32- indash panel insert lights up
rear:
Brake pads Brake pad thickness: 11.5 mm not including backplate Wear limit: 2 mm not including backplate. Always replace on both sides The inner pad on the right side of the vehicle has a wear indicator. When wear reaches a predetermined limit (limit: 2-3 mm), a warning lamp in dash panel insert comes on.
- Brake disc Ventilated brake disc: Ø 294 mm. Brake disc thickness: 22 mm. Wear limit: 19.9 mm. When worn, always renew on both sides of axle.
p4:
Fitting Fronts
i done the rears first , so see below.
Then i done the fronts. . . .
this time,
jack up and wheel chocks, then axel stands. . .
wheel off . . . .
this time im adding the wd40 from the start to give as much time to soak in as possible ( after having trouble with the rears - below)
then spline bit in on the impact gun . .
next up was removing the slide pin caps . .
and using the 9mm long Allen socket to remove the pin bolts. . . .
with them out i used a pry bar against the caliper housing and the old pads to compress the pistons back in . . .
there is no wind back on the fronts. . . . you can use the wind back tool to push them back in . . .
but i find using a pry bar is easier . . .
pry-bar successful .
the calliper can be removed and the pads remove. . .
this is what we had left . . .
id say i got my moneys worth out of these . . .
now . . .
at this point its time to remove the two 21mm calliper bracket bolts, to remove the bracket,
so we can swap the disc. . .
the lower 21mm bolt come out no problem - with the impact.
but the upper 21mm bolt wouldn't budge . . . with the impact or the breaker bar.
to the point i split the socket :mad: - so its game over for today.
i thin the bolt will need heating up and trying again with a new socket.
so for now as the disc are a good thickness . . . . ill carry on as just a PAD SWAP job.
time to refit the new pads . . .
with the pistons pushed full back . . .
one half the pads set pushes into the piston.
the other side sits in the caliper bracket . . .
both together. . .
and add the break pad sensor . . .
which is fitted to the pad for you install it . . .
with the slider pins greased and reinstalled 35Nm . . . . its just time for the spring plates next. . .
so plate back on , , ,
disc spline bolt back in . . .
then wheel back on . . .
now to check the master cylinder oil level and cap. . .
next up is to pump the break peddle, , ,6 or 7 times . . .
this is to take up the slack from the piston push back . . .
ding ding round two . . .
now repeat for the other side of the van.
once both side are done.
pump the break peddle 5-10 times.
then start the engine and then - pump the break peddle 5-10 times - again.
now go for a test drive, being cautious and carful as the new pads / discs will take a while to bed in be 100%,
so drive carefully for the next 50 - 100miles and don't break too hard until they are bedded in.
taking the van for a short test drive . . .
its time to call it a day . . .
I'm not sure how i got so covered in grime. . . . but that's just how it goes.
I've still got the new front discs ready to be fitted on the next pad swap. . .
but i need to get a new 21mm socket. . . .
ill probably get a set of impact rated sockets.
and might need to heat the bolt up . . .
well see next time.
end
p5
fitting fronts - pt2 - discs TBC
p6
fitting rears:
so it begins . . .
locking wheel nut out ,
wheel bolts cracked,
jacked up and axel stands fitted.
wheel off, first thing is to crack the slider pins off . . .
with the bolts removed, we can remove the carrier. . . .
i didn't bother removing the hand break cable,
so carrier out the way . . . we can get to the pads. . .
pads out, . . . . now at this point,
its new pads back in and start to rebuild. but, . . . . . . . .
as we are doing the disc too we have more to disassemble. . .
2x 21mm bolts with the breaker bar are next - they are well tight . . . . 185Nm tight.
so you need to use a long bar or a Impact wrench of serious capacity.
once those bolts are out you can remove the carrier bracket. . .
next up is the disc itself . . . its held on with the wheel bolts . . .
but during factory manufacture, they fit this pesky spline bolt.
first thing to do is WD40 everything . . . round the hub,
in all the bolt holes,
and around the spline bolt . . .
i used the 18v impact with the bit adapter to remove the bolt . . .
it come flying out. . .
once that's out, its just rust and corrosion holding the rotor onto the hub . . . and its stuck on good.
so add some more WD40, , , , , ,
i also put two wheel bolts in loosely. . .
this is to stop the disc dropping off in the next step . . . .
next step = smash the granny out of the rotor . . . . . rotate 90degrees, smash again.
im using a heavy duty rubber mallet . . . . and its taking some beating.
finally it will break free . .
so clean the hub and get your wind back tool ready for the calliper piston wind back.
first step is to prepare the master cylinder . . . . just in case someone has topped-up the master cylinder ( i hate this, why top it up !!!!) - ( it doesn't need topping up - its just pad wear, now with new pads we will be pushing that extra fluid back out the system and it will spill all out the master cylinder !!!)
then lubricate the piston gator with wd40 and start winding back . . . . . . they go in clockwise.
job done. . . . . .
now for the rebuild. . . . .
get the new disc. . . . .
fit and replace the spline hold down bolt. . . .
now to try out the fancy assembly grease kit . . . .
calliper bracket back on and torqued down to 185Nm . . .
then new pad shim plates (supplied with new pads)
then fit new pads wear sensor . . . .
apply the CLIP and PAD grease as shown in the kit diagrams . . . .
now slide the calliper housing back one and replace with new bolts ( supplied in the new pad kit)
I've added a couple of drop of blue thread lock
tourqed down to 35Nm . . .
now its wheel back on . . .
end.
p7
fitting rears pt2.
i used the BLOX SLIDE PINS to help get the wheel back on.
dropping the jack and axel stands. . . .
and do the handbreak 6 or 7 times . . .
once thats done . . .
remember to put the master cylinder back together.
end
p8
kit & tools used . . .
3t jack - https://amzn.to/3E9TEXD
HD Axel stands - https://amzn.to/3KN3ktx
rubber matts - https://amzn.to/3uEfBL5
3set wheel sockets - https://amzn.to/3jCYjIg
breaker bar - https://amzn.to/36cTv9j
wd40 - https://amzn.to/3uGdsyM
impact gun - https://amzn.to/3ObeAC8
socket set 21mm,12mm,13mm - https://amzn.to/3xxfza1
socket reducer set - https://amzn.to/37PX31t
pry bar - https://amzn.to/3vg90Wo
screwdriver set - https://amzn.to/3jAoHCn
9mm long bit - https://amzn.to/3Eb63uc
vw spline set - https://amzn.to/3xrAxXy
caliper wind back tool - https://amzn.to/3rpxr2s
rubber mallet - https://amzn.to/36i5cM0
blue roll - https://amzn.to/3KN9dXF
proslip grease kit - https://amzn.to/3vcQLkG
blue threadlock - https://amzn.to/3JGewa2
torque wrench small - https://amzn.to/3vlUfS9
torque wrench large - https://amzn.to/3JAf29y
p10
looking at that split 21mm socket. . . it just couldn't take the torque and split,
ill need to replace it. . .
this is the old pads and discs removed from the rear.
new pads are 12mm,
to be fair the rears didn't need replacing just yet . . . it was the fronts that triggered the dash light.
you can see the wear sensor is still untouched. - but we done them anyway.
. ( there lasted 23,000 miles and still some left on them )
we had 4.4mm of pad left . . . .
as for the rear disk . . .
it looked fairly good TBH. . .
and measured 24.4mm thick . . . so there is still 5mm left in them (2.5mm per side)
" Brake disc Ventilated brake disc: Ø 294 mm. Brake disc thickness: 22 mm. Wear limit: 19.9 mm. When worn, always renew on both sides of axle."
these are the original discs . . . . so have 52,000 miles on them
this is the old pads removed from the front.
these defo needed replacing. . . . ( there lasted 23,000 miles )
they measured 2.8mm - so almost at the min limit.
"Vehicles with 17'' wheels, 2E4. . Brake pad thickness: 11 mm not including backplate . Wear limit: 2 mm not including backplate."
the front discs are also original . . and don't need replacing just yet.
but i dint get a thickness reading yesterday. . .
ill update soon. . .
questions answered
other
Think its 7mm long bit not 9mm ?? maybe edit that in after
Yep I think your right... but not sure now.
just just checked mine . . . its 9mm
Its listed as a H9.
Big Fronts . . .
smaller fronts . . .
now wondering if the smaller fronts have the same 9mm or if they have smaller guide pin as in 7mm?
Yes... Possible.
I'm defo 9mm.
Just need to 100% confirm that the smaller calliper has the 7mm slide pins long-Allen bit.
I was set to change front pads and disks today (changed rear yesterday). But those slide pins is actually 11mm on my T6, and 11mm seems to be almost impossible to find. Can anyone confirm that on some cars it is 11mm hex key? It is the 204hp diesel 4-motion model 2017 with large disks.
That should be 9mm Allen bolt. Same as my 2018 T32.
done the rear pads and discs today . . . .
I've edited above:
so link back up -
