They’re on the courtesy circuit they are not permanently on.They'll be on permanent like that, if you want them to come on with lights and dim on the roller you need to use the ambient feed, from memory it's in the red connector under the one your in
How did you find these to fit? Just about to get some. Do they stay on while driving as I really like the red glow while driving at night like I have on my Audi?Great all working is now!
For others reference the red/black and red/brown cables are in the white connector. Picture attached
Thanks for the help!
Pretty straightforward after I got help regarding the mismatch between the printed instructions, and the T6 wiring configuration.How did you find these to fit? Just about to get some. Do they stay on while driving as I really like the red glow while driving at night like I have on my Audi?
Sorry blonde moment...They’re on the courtesy circuit they are not permanently on.
If you want them to come on with the instrument lighting connect them behind the dimmer switch next to the light switch or any illuminated button on the dash.
Grey/blue trace is +ve
Brown is -ve
they might be a bit bright though, you can dim them by adding a resistor in series,
Now my brain is working, there's a grey blue ambient feed in the red plug behind the glove box, saves dragging wires all over. The full smd lights are quite bright though without reducing the voltage. I used a dc-dc buck convertor on the advise of @Dellmassive and it worked spot on!
My front and rears are fed from the same point, works a treat. These are ambient lights to be clear, not courtesy lights so they only work with the lights. View attachment 55162
They are these. little switch on the back to select white, red or blue T5 T5.1 Footwell LED Lights Upgrade Kit & Trim Removal KitI'm jumping up and down liked a spoilt child now.....I want these.....big time! Come on @RedUn.....do an idiot guide and a link just for me! When I say idiot guide, I mean idiot guide!!![]()
They are these ones I went for...you can also find them cheaper on the aliexpress if your happy to wait a few weeks for delivery.Have you a link to where you got them from @RedUn?
I've got the same ones in white that I'm going to link on the courtesy circuit for puddle lights, you could swap them to the door cars and fit red ones in the footwell? Saves making another cut out anyway?I've already got the white led footwell lights that activate when you open the door,its the red ambient lights that i want to run parallel.
More than happy to help out, which bit do you need to know exactly? Would a shopping list help?I'm jumping up and down liked a spoilt child now.....I want these.....big time! Come on @RedUn.....do an idiot guide and a link just for me! When I say idiot guide, I mean idiot guide!!![]()
@Deaky, are yours wired in as courtesy lights only or do they come on with the headlights?They are these. little switch on the back to select white, red or blue T5 T5.1 Footwell LED Lights Upgrade Kit & Trim Removal Kit
Oh my god, I'm having a little moment here......puddle lights..... ambient lights..... "NURSE..... NURSE..... GET ME MY TABLETS!"I've got the same ones in white that I'm going to link on the courtesy circuit for puddle lights, you could swap them to the door cars and fit red ones in the footwell? Saves making another cut out anyway?
Last time I was in Thirsk I stayed in one of the pubs, great place with great roads tooOkay @RedUn, what I need to know is when are you coming to Thirsk to do mine?
Only kidding..... Right so you appear to have fitted them in the rear of the front seat bases so you bought two sets, right??? If so, how did you connect up both sets and how did you route the cables?
Thanks in advance bruv!![]()
