Hi all.
I'm. Looking to lower my T6 full camper conversion. Just wanting to close the gap between the tyre and arch. It's on 20inch wheels.
I'd say probably 20mm at the rear and 40ish on the front
Any advice on the different spring weight ratings and photos would be great.
Thanks John
My outlook on camper life is a little different to most and I have advised the correct way to do this many times on this forum . I am here to assist with solid advise and whilst I am in the business I feel I can speak with authority having seen the disasters that have come my way.
Spring rates are of primary concern when modding a van and must be up to the job . if you add weight , you must increase spring rate . Simply turning up the adjuster on a Coil over kit solves the Visual tail sagging problem only . ., In reality the rear spring is then pre loaded too much and the rear suspension runs out of travel way too soon ( harsh ride ) the bigger the spec of the van the worse this gets . Height adjustable suspension kits are designed to change ride height NOT carry more weight .
You will see comments about springs alone being bad , this is for 2 reasons :-
1 The people selling them don't know which is the correct spring to use for the mods and weight of the van , ( Discount sellers are rarely specialists ) I have helped more than half a dozen van owners who were sold the incorrect spring and the van didn't sit correctly .
2 Fitting sport lowering springs which are 20 % stiffer can not be controlled well by STANTARD shocks so the ride is crashy and poor . If sport shocks are used and adjusted correctly with the lowering springs the results are as amazing , and definitely better than coil overs but not too low ??
If you want the arch gap closed completely be warned this is too low and even with quality equipment there is very little comfort when off the motor ways.
Too low often gives the following problems
1 Poor wheel alignment which cant be adjusted out , Result poor tyre wear from Bump steer and incorrect camber and Toe
2 Drive shafts pushed to beyond manufacturers spec ( 7 % from Horizontal ) and CV cages breaking ( not covered by VW warranty )
