arch liner
  1. W
    Arch liner / splash guard clips?
    I thought these would be easy to find online but seems not?? The head popped off one of my clips when refitting the front arch liner so I want to get hold of another. They are the mushroom head type which pushes down into the clip once it is place. I can find loads which are similar but not...
  2. Strange Al
    Front Arch Liner modification
    Morning, I was hoping someone here could give me a clue as to how much extra space at the top of the front Arch you can get by carrying out the basic Arch Mod? I've seen that it's fairly straightforward - remove screw bend back bracket and push liner behind the bit higher up. But I've not seen...
  3. Nik
    20” wheel arch mod??
    Hi, Great forum some really interesting stuff here. I’m new to the forum and new to T6 ownership (I have a T6 2018 - T30 kombi) I bought it with stance+ street coilvers and 20” Velare Alloys. It looks awesome and overall I’m really really happy with it, but I have an issue with these wheels...
  4. S
    Can anyone help me with what this is please? Inside the little removable cover in the front near side wheel arch [Resolved]
    I had a bump and it broke away and was leaking water. It’s booked in to get fixed, but I need to go on a decent drive and just want to make sure it’s not important. It’s not leaking any more and there are no lights on the dash. Cheers.
  5. Texxaco
    Front wheel arch-liner fitting kit
    Can anyone help with part numbers for the inner wing liner fitting kits? In can find the screws that hold the wheel arch liner in place but not the plastic inserts that fit in the body of the van that they screw into. Thanks for your help all.
  6. Stu1974
    T32 4Motion rubbing
    Hi my T32 2018 4 Motion is rubbing or what feels like bottoming out at the rear. The van came fitted with B14 coil overs. I've bought and fitted the Transporter HQ recommend setup 265 40 20, with correct offset rim and Goodyear asymmetric 3 tyres which are Awesome ride quality at 42psi by the...
  7. K
    Wheel Arch Liner Part Numbers
    Hi Guys, Does any on have the part numbers for the wheel arch liners for a T6? I'm after the front passanger side and rear drivers side but if someone has them all it might help others, cheers Kev!
  8. N
    Wheel arch liner fitting/removal
    Hi Folks, probably very easy, however in my rush to change my side indicators in the rain, passenger side cable and connector has fallen into the inner wing. I haven’t looked as its now dark but is the wheel arch liner an Easy remove?
  9. K
    Sound-deadening internally under wheel-arch plastic protector.
    Hello all, has anybody tried fitting a set of wheel arch protectors of a wheel arch that has had Silent coat / Deadmat 2mm applied? Thinking it might good to sound deaden the arch but I don't want a carpet covering.. many thanks.
  10. TransporterTim
    Knocking noise from n/s/f
    Hi everyone I’ve been having an on going knocking issue from my my16 t6 for a while now. While it was in for service at VW they noticed my n/s/f damper was wet and had failed. I had this replaced on my extended warranty I run 30mm eibach springs and have done since new. I’ve been back a few...
  11. RattyMcClelland
    Wheel-Arch access panels for lights
    In the n/s arch lining, the fog light cover hole access thingy magiggy is missing. Can't figure out what's it's called so I can buy a new one. Anyone have a part number?
  12. T6180
    Front Arch Lining - Heating Up
    Has anyone changed/cut/heated up their front arch liner on the outside to stop the wheel rubbing the bolt at the top of the arch because of a 20x9 et35 offset? Or does anyone have a picture of how the arch liner looks? Weird request I know but it's raining outside and I dont fancy taking a...
  13. highwaycollective
    First Time Van Owner (no Idea Why I Waited So Long).
    I have been lurking on the forum for a few months, and I have to say it has been an invaluable help as I get going with my first van. I have owned VW's my whole life, and have done loved owning and driving everything from a MK1 Caddy, to various generations of the GTI. I have wanted a Van for...
  14. M
    Heat Gun / Wheel Arch Extensions
    Hi Everyone, I posted a wheel rub thread and I keep going round in circles (no pun intended), which is down to me not anyone elses posts! I'm going to try the heat gun method on the inner wheel arches (I have looked and I can see where the slight rubbing is). Any tips on how to do it please -...
  15. Montecha
    Floor sound-deadening
    What's the best sound deadening for a Kombi floor? The roof, sides and wheel arches are all done, and was always planning to do the floor as well. I think the 20s generate a lot of road noise so figured this could be a nice little job for the B/H weekend. Are folks sticking with a 2mm Dynamat...
