I have a 2016 T6 California Ocean with the factory Eberspacher cabin heater and Webasto auxillary coolant heater. The Webasto is only controlled by the main VW control unit and I have no ability to switch it on or off. It only comes on when certain parameters are met. i.e. less than 5 degC cold start and more than ¼ tank of fuel.
I had a break in the fuel line that feeds both of these heaters which is now fixed. So the Eberspacher is fully operational again but the Webasto won’t even try to run when it should i.e. cold starts below 5 deg C.
The Webasto heater was definately running the day before I resolved the fuel line issue. But when I say working, it was attempting to pump fuel and was running the turbine but not heating, the exhaust was only blowing out cold air. So this might have been its 3rd and final attempt to run. I have read that the Wabasto will lock out after 3 failed start attemps.
I managed to get a Carista ODB reader and now get the following codes for the Auxilliary heater module.
Auxiliary heater
Part #: 7E0963273A
Component: STH-T5GP2
Coding: 4101 (hex)
Fault codes:
00056 Blower engine for temperature sensors inside (V210)
00002 Transmission Control Unit
00057 Actuator shut-off valve b-column and floor space, right (V211)
00135 Left Front Wheel Acceleration Sensor (G337)
I think that the fault code descriptions may be wrong, especially the 00002 & 00135 as the Aux heater module can’t have anything to do with the transmission and the left front wheel acceleration sensor. But these codes could be something to do with my Webasto heater lockout issue. The Carista won’t clear these codes, so a dealer visit is looking more likely, unless I can find someone local (South Cheshire) with a VAG-COM which should be able to clear them.
Any ideas on what the codes really mean and advice on how to reset them before I make the dreaded visit to the main dealer.
Auxiliary heater
Part #: 7E0963273A
Coding: 4101 (hex)
Fault codes:
