Hi!
A friend has a problem with the webasto in his car since 2 weeks.
When we use the remote, it's flashing green many times during +/- 2 seconds.
When we use the button in the car, goes, then after few seconds it goes off.
With VCDS, for the Aux Heater I find this :
For the engine :
So, is it a broken pump, if I undertand well ?
Thanks for your help
Address 18: Aux. Heat (J364) Labels:| 5Q0-963-272.clb
Part No SW: 5Q0 963 272 C HW: 5Q0 963 272 C
Component: STH-MQB 006 0069
Coding: 9301
Shop #: WSC 73430 031 00000
ASAM Dataset: EV_AuxilParkiHeateWOS 002014
ROD: EV_AuxilParkiHeateWOS.rod
VCID: 36362E6AF8C5B3AAC5F-8062
Auxiliary heating remote control:
Subsystem 1 - Part No SW: 5Q0 963 513 HW: 5Q0 963 513
Component: R149 T91-LIN 003 0301
Serial number: 00000000000000644218
3 Faults Found:
0369 - Coolant Circulation Pump
B137E 52 [00001000] - Not Activated
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 15
Reset counter: 0
Mileage: 234340 km
Date: 2022.12.12
Time: 05:19:49
Parking heater: operating condition: Start
7A
Coolant temperature of parking heater: -21 °C
Coolant temperature: -18 °C
Engine running status: not detected
Fuel level: 35 l
Heating performance: 2080 W
0139 - Recirculation pump
B1382 15 [00001001] - Open or Short to Plus
Freeze Frame:
Fault Priority: 3
Fault Frequency: 6
Reset counter: 216
Mileage: 261961 km
Date: 2023.11.20
Time: 07:07:46
Parking heater: operating condition: After-run - burnout
92
Coolant temperature of parking heater: 17 °C
Coolant temperature: -15 °C
Fuel level: 30 l
Heating performance: 5000 W
0135 - Heater Unit Locked
B138F 00 [00001001] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 217
Mileage: 262033 km
Date: 2023.11.20
Time: 15:46:08
Parking heater: operating condition: locked
71
Coolant temperature of parking heater: 73 °C
Coolant temperature: 70 °C
Engine running status: detected
Fuel level: 24 l
Heating performance: 0 W
For the engine :
Address 01: Engine (J623-CLHA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 M HW: 04L 907 309 B
Component: R4 1,6L EDC H22 5517
Revision: 84H22--- CVN: B53D877B
Coding: 0111001A043401090000
ASAM Dataset: EV_ECM16TDI01104L906021M 002009
ROD: EV_ECM16TDI01104L997021.rod
VCID: 2F381B0E079F8262869-807A
VINID: 91D49A5C779505500010314020E1681213
8 Faults Found:
12002 - Particulate Filter; Differential Pressure Sensor
P2453 00 [01100000] - Implausible Signal
Intermittent - Not Confirmed - Tested Since Memory Clear
7158 - Please Check DTC Memory in CAN Gateway (J533)
U1008 00 [00100000] - -
[Diagnostic interface for data busRead out DTC]
18825 - Coolant Pump for Intercooler
P190E 00 [00100000] - Supply Voltage
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 261904 km
Date: 2023.11.19
Time: 14:29:35
Engine RPM: 768.00 /min
Normed load value: 40.0 %
Vehicle speed: 0 km/h
Coolant temperature: 52 °C
Intake air temperature: 10 °C
Ambient air pressure: 970 mbar
Voltage terminal 30: 14.560 V
Unlearning counter according OBD: 3
17273 - No Communications with Power Steering Control Module
U0131 00 [00100000] - -
5608 - No Communications with Steering Angle Sender (G85)
U0126 00 [00100000] - -
7150 - Implausible Data Received from Steering Angle Sensor Module (G85)
U0428 00 [00101000] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 262210 km
Date: 2023.11.23
Time: 12:59:40
Engine RPM: 855.50 /min
Normed load value: 98.0 %
Vehicle speed: 7 km/h
Coolant temperature: 87 °C
Intake air temperature: 89 °C
Ambient air pressure: 940 mbar
Voltage terminal 30: 14.320 V
Unlearning counter according OBD: 9
17158 - Databus
U1123 00 [00101000] - Received Error Message
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Mileage: 262210 km
Date: 2023.11.23
Time: 12:59:40
Engine RPM: 980.00 /min
Normed load value: 92.5 %
Vehicle speed: 5 km/h
Voltage terminal 30: 14.720 V
Drivetrain coordinator: ACC fault status-Bits 0-7: 0
Drivetrain coordinator: brake fault status-Bits 0-7: 4
Drivetrain coordinator: brake function status-Bits 0-7: 0
Acceleration: -1.079 m/s²
21125 - Implausible Data Received from Airbag Control Module
U0452 00 [00100000] - -
Readiness: 0 0 0 0 0
