Hi it's a Discover media navigation system.CarPlay or carnet?
What radio?
They may have cracked the ‘protection’ but if you do a search here on the forum you will discover that not all the USB ports fitted by VW are compatible so it’s perhaps not as straightforward as suggested.Ooh, thanks for that.
Just had App connect activated today by North East VAG adaptations.They may have cracked the ‘protection’ but if you do a search here on the forum you will discover that not all the USB ports fitted by VW are compatible so it’s perhaps not as straightforward as suggested.
Cheers for reply - checked your site out - can this be done remotely?North East VAG Adaptions | Durham
North East VAG Adaptions, Durham, Durham. 10,718 likes · 52 talking about this. Available for most VAG vehicles 2008+ onwards.www.facebook.com
Yes- you’ll need a laptop and the correct USB socket. He’ll dial in to your laptop, do the business, then delete the file he used and then empty your Recycle Bin. Takes 10 mins tops.Cheers for reply - checked your site out - can this be done remotely?North East VAG Adaptions | Durham
Cool ok - well I work in IT anyway so have all the gear....Yes- you’ll need a laptop and the correct USB socket. He’ll dial in to your laptop, do the business, then delete the file he used and then empty your Recycle Bin. Takes 10 mins tops.
Back to this topic one year after.
Still looking for a solution to unlock app connect without financing Volkswagen extortion...
There is: North east vag adaptations see 2 posts above plus he’s a top blokeMe too I understand VW want £400 to unlock app connect there must be a work around out there with all the clever people on here, even if you have to change the stock usb port physically
