Has anyone put side steps on their Caravelle in preference to side bars? My youngest is struggling stepping out of the vehicle so am thinking of fitting side steps to help him but I am worried that they will stick out a bit.
that looks very nice @Jordy, finally I bet you are very chuffed
Hi jamesabell. I got the bars from JustKampers (free p&p!) as these had the low profile brackets that required minimal cutting but even then I did need to cut a tiny bit out of the under trays to allow the tray to fit flush around the brackets, but nothing substantial. A dremel worked fine in doing the mods and I only really needed to take about 1/2" out of each tray. Also if you have the means then consider cutting a few mm off the length of the bolts after fixing the brackets that hold the brackets to the chassis as they do push the under trays out slightly, otherwise a 12mm hole in tray will work fine. Roof bars were much easier to fit but hoping I put enough silicone sealant in the holes - waiting for the next band of rain to see if I have any leaks!Hi Jordy, looking good and following your improvements as I endlessly await the delivery of my SB Exec. The more time I have the more I add to to the list of things I want to get. Was there any cutting of the tray for this and how bad was it? I think they are round bars rather than angle bars as they look more purposeful in the picture
@Jordy how did you get on with the horn upgradeMy Stebel Magnum horns arrived today so currently scratching my head trying to figure out how to fit these!
Not completed yet. Realised that I needed some crimp connectors as I need to wire a relay into the circuit so just waiting for bits to come and then for a break in the weather!@Jordy how did you get on with the horn upgrade
The velle looks great, I miss ours bought it in 2011 and kept it for nearly 5 years which is an amazing feat for me !Just picked this up on Friday. The family are loving it but I need to get another bench and take out the two swivel single seats to turn it into an 8 seater. Any ideas of where to go or look appreciated View attachment 110228
