T6 sliding door buzzer location
Naparm
Hi need some help
Does anyone know where the buzzer is for electric sliding doors on a t6 Caravelle 2017
Thanks.
On the door controller module PCB. ( small peizo electric sounder)
think there was a post a while ago about removing the sounder........
Thanks bud where abouts the controller I will also try and find the other post too
Thanks again
Thanks again will have a look tomorrow and let you know how I get on
Cheers for all tour help
Think in a standard van the sides are mirrored, yours is prob different due to rear heater unit
I turned off the beep on my Tiguan tailgate with Carista, don’t know if it’s possible on the T6.
2019 T6 LWB just above the wheel arches the control unit is next to the motor.
the little buzzer bleeper is soldered directly into the pcb .
So you would be brave to remove it in case it causes a failure to the operation of the doors.
several relays in there with multiple wires.
