I know this has been discussed various times - and I've seen some good posts on wiring up a momentary switch into the power latching switch, but I have a few questions...
I've got a Kombi with the electric opening tailgate (not just power latching), but has no way to open it from the inside, so I've been looking at wiring something into the external release switch as per the existing posts.
However, I've managed to get hold of an OEM switch (i think its from the drivers door from a Caravelle maybe?) - but have read that those have a 180 ohm resistor in them (and my multimeter shows resistance between two of the pins when the switch is activated) so I assume you cant just wire that in to connect the wires for the existing rear release ? - as they are designed to connect to the can bus?
I was thinking I could wire it into the same pins as the open/close button on the internal bottom of the tailgate - but that is deactivated when the tailgate is shut - so not much use!
The external handle however does both open and close the tailgate however - so that is the ideal one to wire into.
Is the electric tailgate opening switch different to the power latching one? Would it be possible to simply piggy back off the external handle - or does the resistance prevent that from working?
If not, would it be possible to solder part of the PCB in the switch to bypass the resistor ?
Or is it easy to wire this switch into the existing loom somewhere so it works as it would if it was factory fitted?
Anyone done this?
Also - does anyone know where to get the plug for the wires to plug into it? its the same as the electric window switch plug...
Anyone done this?
