Mk8 R steering wheel Update!
I’ve installed my Golf 8R heated wheel in my T6.1 along with a 5Q0 slip ring
My van is a 2021 5speed manual gearbox
With wiring pin out list for the T14 and T16 plugs posted by
@Pauly and
@Rems all worked perfectly Cruise, horn menus everything except for the heater button
I have power to the heater terminals on the slip ring and I have installed canbus high and low but I would like to confirm it’s on the correct pins T14 pin 5&6?
Also I have tapped into can high and low behind the radio in the loom for the main radio ISO plug can high and low grey connector
orange/ brown can low
and Purple can high
Could you confirm this is correct or should I be joining the canbus in another location?
I have the three stage heating control I can select in the radio screen after turning it on in HVAC in VCDS and the icon on the bottom of the consumers screen but the heating will not activate
The button on the steering wheel does nothing either
Just trying to rule out a wiring problem before I go further with more coding
Any advice would be much appreciated thank you
