T6.1 fog-light retrofit
Please share
(1) full VCDS Auto-Scan,​
(2) blockmap of 09-Central Electrics​
(3) adaptation map of 09-Central Electrics​
sorry for the late reply, the customer went away with the van and we've only just got him back in for another check. After a few days one fog light was working and cornering lights were working but the wrong way round, turning left would turn on the right light and turning right would turn on the left light. However, we had both fogs and cornering lights working correctly for around an hour and then after a few ignition cycles everything stopped working again. We've checked the pins going into the BCM and all seems good, ground is also good.
Here is the full auto scan below:
Code:
Monday,09,February,2026,12:47:31:00447
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 25.3.2.0 (x64)  HEX-NET2 CB: 0.4671.5
Data version: 20250822 DS365.0
www.Ross-Tech.com
VIN: WV1ZZZ7H2PX034140   License Plate:
Chassis Type: 7H-VN46 (3Q0)
Scan: 01 03 08 09 10 13 15 17 19 44 5F 75
VIN: WV1ZZZ7H2PX034140   Mileage: 77940km-48429miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
75-Telematics -- Status: Malfunction 0010
Address 01: Engine (J623-DNAB)       Labels:. 05L-907-309-V1.clb
   Part No SW: 05L 906 023 NK    HW: 05L 907 309 AD
   Component: R4 2.0l TDI   H80 2577
   Revision: NBH80---    CVN: 8EA0F67B991E9EBCA3C795CF64CF85E9A3C795CF43FB2DAA
   Coding: 001100340324050800000000000000000000000000000000
   Shop #: WSC 00035 377 00129
   ASAM Dataset: EV_ECM20TDI01105L906023NK 006001
   ROD: EV_ECM20TDI01105L906023JG.rod
   VCID: 7EAE8D8270776E0AFCF-802A
   VINID: 9E606AAAA1D80A0A000C404400B46E5130
3 Faults Found:
26468 - Ignition Switch; ON Position
          P2532 00 [00100000] - Short to Plus
          Intermittent - Not Confirmed - Tested Since Memory Clear
23695 - Implausible Data Received from Body Control Module (Central Electric)
          U0422 00 [00100000] - -
41157 - Reductant Level too Low
          P203F 00 [00100000] - -
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104)       Labels: 7LX-614-517-V1.clb
   Part No SW: 7LB 614 517 B    HW: 7LB 614 517
   Component: ESC_base      H01 0800
   Serial number: 08509450230117
   Coding: 30552752484AEE890C55E4A812667726392124B8
   ASAM Dataset: EV_Brake1ESP90iBOSCHVN46X 003012
   ROD: EV_Brake1ESP90iBOSCHVN46X_003.rod
   VCID: 3FD0308637FDA702B79-806A
No fault code found.
Address 08: Auto HVAC (J301)       Labels:* Redir Fail!
   Part No SW: 7LA 907 426 K    HW: 7LA 907 426 K
   Component: AC Manuell    H01 0701
   Coding: A03110000810030001000800504001050000000000000000800000000000
   Shop #: WSC 00035 377 00146
   ASAM Dataset: EV_AirCondiBHTCVN54XT6PA 001002
   ROD: EV_AirCondiBHTCVN54XT6PA_VN46.rod
   VCID: 4BC8145673450BA22B1-801E
   Rear air conditioning block 1:
Address 09: Cent. Elect. (J519)       Labels: 2QX-937-BCM-V1.clb
   Part No SW: 2Q0 937 090 E    HW: 2Q0 937 090 C
   Component: BCM A0 Std+   H12 0963
   Serial number: 00102302500172 Dataset Number: V03935366EL 0001
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_BCMA0 208001
   ROD: EV_BCMA0_208_VW27.rod
   VCID: 343A6FAA0EBB745A5AB-8060
   Driver door control module:
   Subsystem 1 - Part No SW: 7L1 959 405     HW: 7L1 959 163
   Component: FHSG_DRV  001 0002
   Serial number: 00000000000065090160
   Coding: 1F0008
   Front passenger door control module:
   Subsystem 2 - Part No SW: 7L1 959 406     HW: 7L1 959 164
   Component: FHSG_PSG  001 0002
   Serial number: 00000000000065078960
   Coding: 050000
   Anti-theft alarm system sensor:
   Subsystem 3 - Part No SW: 5Q0 951 172 A    HW: 5Q0 951 172 B
   Component: Sensor, DWA  005 0403
   Serial number: 000000000ZL2302407PB
   Alarm horn:
   Subsystem 4 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Component: Sirene, DWA  005 0314
   Serial number: 00000000000051441332
8 Faults Found:
5642 - Bulb for Rear Left Turn Signal
          B11E9 15 [00001001] - Open or Short to Plus
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 4
                    Reset counter: 94
                    Mileage: 77548 km
                    Date: 2026.01.26
                    Time: 09:39:22
                    Zusaetzliche Umgebungsdaten-Terminal 15 status: On
                    Zusaetzliche Umgebungsdaten-Terminal 50 status: OFF
                    Zusaetzliche Umgebungsdaten-Low beam: Not operated
                    Zusaetzliche Umgebungsdaten-OFF: Not operated
                    Zusaetzliche Umgebungsdaten-Outside temperature: -50.0  C
                    Zusaetzliche Umgebungsdaten-Automatic high beam assist: Not operated
                    Zusaetzliche Umgebungsdaten-Position lamps: Not operated
                    Zusaetzliche Umgebungsdaten-Parking light left: Not operated
                    Zusaetzliche Umgebungsdaten-Parking light right: Not operated
                    Zusaetzliche Umgebungsdaten-CAN-Bus_aktiv: On
                    Zusaetzliche Umgebungsdaten-last wakeup: keine Stoerschutzursache
                    Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (CAN): OFF
                    Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (HW): OFF
                    Zusaetzliche Umgebungsdaten-voltage measurement: 14.5 V
5898 - Bulb for Left Side Turn Signal
          B12D0 15 [00001001] - Open or Short to Plus
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 4
                    Reset counter: 94
                    Mileage: 77548 km
                    Date: 2026.01.26
                    Time: 09:39:16
133387 - Voltage Supply; Terminal 30 for Central Locking
          B140F 13 [00001000] - Open Circuit
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 122
                    Mileage: 77548 km
                    Date: 2026.01.26
                    Time: 09:59:58
                    Zusaetzliche Umgebungsdaten-Terminal 15 status: OFF
                    Zusaetzliche Umgebungsdaten-voltage measurement: 12.4 V
137217 - Outside temperature sensor
          B103F 1B [00001000] - Resistance Too High
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 122
                    Mileage: 77548 km
                    Date: 2026.01.26
                    Time: 10:00:01
                    Zusaetzliche Umgebungsdaten-voltage measurement: 12.5 V
267012 - No Communications with Anti-Theft Siren / Alarm Horn
          U10F3 00 [00001000] - -
          [Sirene-DWA -> kein Signal/Kommunikation]
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 122
                    Mileage: 77548 km
                    Date: 2026.01.26
                    Time: 09:59:57
395274 - Control Circuit for Signal Horn
          B1344 13 [00001000] - Open Circuit
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 122
                    Mileage: 77548 km
                    Date: 2026.01.26
                    Time: 09:59:58
608780 - Rotary Latch Motor for Sliding Door; Rear Pass. Side
          B1A73 F0 [00001000] - Electrical Malfunction
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 134
                    Mileage: 77940 km
                    Date: 2026.02.09
                    Time: 10:11:47
                    Zusaetzliche Umgebungsdaten-Automatic high beam assist: operated
                    Zusaetzliche Umgebungsdaten-voltage measurement: 13.1 V
919560 - Light Switch
          B126A 29 [00001000] - Signal Implausible
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 13
                    Reset counter: 134
                    Mileage: 77548 km
                    Date: 2026.01.26
                    Time: 11:31:35
Address 10: Park/Steer Assist (J446)       Labels:| 5Q0-919-283.clb
   Part No SW: 5QA 919 283 H    HW: 5QA 919 283
   Component: PDC 4 Kanal   H10 0075
   Serial number: 000150059323028 Dataset Number: V03935313JH 0001
   Coding: 0601050001
   ASAM Dataset: EV_EPHVA14AU3700000 009050
   ROD: EV_EPHVA14AU3700000_009_SK25.rod
   VCID: 4FF00046875D3782479-801A
Address 13: Auto Dist. Reg (J428)       Labels:| 2Q0-907-572.clb
   Part No SW: 2Q0 907 572 AA    HW: 2Q0 907 572 D
   Component: ACCCONTIMQB   H09 0396
   Dataset Number: V03935351GN 0001
   Coding: 2800600200FF8748949C815500508700000000000000000004
   ASAM Dataset: EV_ACCMRRCONTIVW376 003018
   ROD: EV_ACCMRRCONTIVW376_VW41.rod
   VCID: 73B8ACB64B353362831-8026
1 Fault Found:
1389 - Function Restricted due to Insufficient Voltage
          U1400 00 [00001000] - -
          [FAULT_VBAT_BUSMON_LOW]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 121
                    Mileage: 77519 km
                    Date: 2026.01.21
                    Time: 14:26:59
                    Voltage terminal 15: 10.3 V
                    Control Module temperature: 24  C
                    Vehicle speed: 0.00 m/s
                    Longitudinal acceleration: -0.03 m/s
                    Adaptive distance regulation: status: ACC_reversible_error
Address 15: Airbags (J234)       Labels:| 2Q0-959-655.clb
   Part No SW: 2Q0 959 655 AN    HW: 2Q0 959 655 AN
   Component: VW22Airbag    020 0511
   Revision: --------    Dataset Number: V03935346ZR 0001
   Coding: 8800C000000000007C0001CF008C40030065
   ASAM Dataset: EV_AirbaVW22BPAVW27X 001036
   ROD: EV_AirbaVW22BPAVW27X.rod
   VCID: 0944EE5E39B959B2D9D-805C
Address 17: Instruments (J285)       Labels:| 7LA-920-XXX-V1.clb-SRI3
   Part No SW: 7LA 920 941 B    HW: 7LA 920 941 B
   Component: KOMBI         202 8500
   Coding: 27A412002080260001882A010401000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009071
   ROD: EV_DashBoardVDDMQBAB_VN46.rod
2 Faults Found:
13639936 - Databus
          U1123 00 [00001000] - Received Error Message
          [Steuerger t f r BCM / Bordnetz / el. ZE: bitte Fehlerspeicher auslesen]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 3
                    Reset counter: 122
                    Mileage: 77548 km
                    Date: 2026.01.23
                    Time: 14:15:05
9456681 - Key
          B104C 29 [00001000] - Implausible Signal
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Mileage: 77548 km
                    Date: 2026.01.26
                    Time: 09:36:53
Address 19: CAN Gateway (J533)       Labels:| 3Q0-907-530-V1.clb
   Part No SW: 3Q0 907 530 AR    HW: 3Q0 907 530 G
   Component: GW MQB High   527 5504
   Serial number: 26012311603466 Dataset Number: V03935367RM 0001
   Coding: 030100044F056A0000000048000F00010001070000000000000000000000
   Shop #: WSC 00035 377 00184
   GVL: 01443C0000000000400080008000480000000000000000000000000000000000
   ASAM Dataset: EV_GatewNF 013026
   ROD: EV_GatewNF_SK25.rod
   VCID: 7F507086777D6702F79-802A
   Generator:
   Component: 5-00-14-00-04
   Multifunction steering wheel control module:
   Subsystem 2 - Part No SW: 3G0 959 442 AH    HW: 3G0 959 442 AH  Labels: 3C8-959-537.CLB
   Component: E221__MFL-PR6  H50 0500
   Serial number: PR6-0440071353224609
   Coding: 280C00
   Battery Monitoring Control Module:
   Subsystem 3 - Part No SW: 7E0 915 181 N    HW: 7E0 915 181 N
   Component: J367-BDMConti  H03 1052
   Serial number: 7734330200230118037B
1 Fault Found:
8526361 - LV Energy Management
          B1802 F1 [00001000] - Warning Triggered
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 8
                    Reset counter: 122
                    Mileage: 77548 km
                    Date: 2026.01.23
                    Time: 15:26:14
                    Terminal 30 power supply: 11.0 V
                    Terminal 15: On
Address 44: Steering Assist (J500)       Labels:| 2N0-909-143.clb
   Part No SW: 7LA 909 144 G    HW: 7LA 909 144 D
   Component: EPS_MQB_ZFLS  751 7160
   Dataset Number: V03935340DA 0001
   Coding: 0106
   ASAM Dataset: EV_SteerAssisMNB 002015
   ROD: EV_SteerAssisMNB.rod
   VCID: 46DE25626827F6CAF4F-8012
Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-ENT2.clb
   Part No SW: 3CN 035 869 E    HW: 3CN 035 869 E
   Component: MU-E-D-ER     720 0970
   Serial number: 31012300021889 Dataset Number: V03935343RV 0001
   Coding: 066401003C00000041110101008000001F0000C60000010000
   ASAM Dataset: EV_MUEnt4CGen2LGE 001044
   ROD: EV_MUEnt4CGen2LGE_VN46.rod
   VCID: 48C22B5A6233E0BA063-801C
6 Faults Found:
0005 - Antenna Amplifier 1 for Radio
          B126D 13 [00001000] - Open Circuit
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 122
                    Mileage: 77548 km
                    Date: 2026.01.23
                    Time: 11:28:40
                    Voltage terminal 30: 12.0 V
                    Status of antenna 1 for radio-Antenna current: 0 mA
                    Status of antenna 1 for radio-Connection between radio and antenna amplifier: Open circuit
                    Status of antenna 1 for radio-Connection between antenna amplifier and antenna: Not available
                    Status of antenna 1 for radio-Reception level antenna 1: 21 dB V
0006 - Antenna Amplifier 2 for Radio
          B126E 13 [00001000] - Open Circuit
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 122
                    Mileage: 77548 km
                    Date: 2026.01.23
                    Time: 11:03:09
                    Voltage terminal 30: 11.8 V
                    Status of antenna 2 for radio-Antenna current: 0 mA
                    Status of antenna 2 for radio-Connection between radio and antenna amplifier: Open circuit
                    Status of antenna 2 for radio-Connection between antenna amplifier and antenna: Not available
                    Status of antenna 2 for radio-Reception level antenna 2: 17 dB V
0517 - Front Right Bass Speaker
          B1062 13 [00001000] - Open Circuit
          [Tieftonlautsprecher Kanal 2: Unterbrechung (DC-Diagnose)]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 122
                    Mileage: 77548 km
                    Date: 2026.01.23
                    Time: 10:53:19
0522 - Front Left Bass Speaker
          B105F 13 [00001000] - Open Circuit
          [Tieftonlautsprecher Kanal 3: Unterbrechung (DC-Diagnose)]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 122
                    Mileage: 77548 km
                    Date: 2026.01.23
                    Time: 11:07:14
                    Voltage terminal 30: 12.1 V
0013 - Antenna Amplifier 1 for Digital Radio
          B1270 13 [00001000] - Open Circuit
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 122
                    Mileage: 77548 km
                    Date: 2026.01.23
                    Time: 11:03:09
1637 - Interface for External Media
          U11B8 00 [00001000] - No Communications
          [USB - communication error]
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 131
                    Mileage: 77789 km
                    Date: 2026.02.08
                    Time: 12:54:26
                    Voltage terminal 30: 12.2 V
Address 75: Telematics (J949)       Labels:* Redir Fail!
   Part No SW: 5WA 035 282 C    HW: 5WA 035 282
   Component: OCUGen3Low    H16 0200
   Serial number: 0000000212NVNV1 Dataset Number: V03935383XY 0001
   Coding: 06462000196818008005460160000607
   ASAM Dataset: EV_OCUGen3Low 003008
   ROD: EV_OCUGen3Low.rod
   VCID: 44DA3F6A5E1BC4DAEAB-8010
2 Faults Found:
2566 - GPS Antenna
          B1054 13 [00001000] - Open Circuit
          [GPS-Antenna - Interruption]
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 28
                    Mileage: 77548 km
                    Date: 2026.01.23
                    Time: 10:51:26
                    Voltage terminal 30: 12.3 V
1644017 - Online Services
          B1915 F1 [00001000] - Temporary Function Restriction due to Battery Budget
          [Functional restriction due to insufficient power budget]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 4
                    Reset counter: 12
                    Date: 2000.00.00
                    Time: 00:00:00
                    Remaining long term energy budget: 0 mAh
                    Remaining short term energy budget: 851 mAh
                    Wake up cycles counter: 2377
End----(Elapsed Time: 01:18, VBatt start/end: 11.8V/12.0V. VIgn 11.8V)-----
------------------------------23 Faults Found------------------------------
Current Adaptation is:
Leuchte12NL LB40-Lasttyp 12 > Wert auf "10 - allgemeine Scheinwerfer" setzen
Leuchte 12NL LB40-Lampendefektbitposition 12 > Wert auf "38" setzen"
Leuchte 12NL LB40-Fehlerort mittleres Byte DTC-DFCC 12 > Wert auf "22" setzen
Leuchte 12NL LB40-Lichtfunktion A 12 > Wert auf "Nebellicht links" setzen
Leuchte 12NL LB40-Lichtfunktion B 12 > Wert auf "Abbiegelicht rechts" setzen
Leuche 12NL LB40-Dimmwert AB 12 > Wert auf "100" setzen
Leuchte13NL RB3-Lasttyp 13 > Wert auf " 10 - allgemeine Scheinwerfer" setzen
Leuchte13NL RB3-Lampendefektbitposition 13 > Wert auf "42" setzen"
Leuchte 13NL RB3-Fehlerort mittleres Byte DTC-DFCC 12 > Wert auf "23" setzen
Leuchte 13NL RB3-Lichtfunktion A 13 > Wert auf "Nebellicht rechts" setzen
Leuchte 13NL RB3-Lichtfunktion B 13 > Wert auf "Abbiegelicht links" setzen
Leuche 13NL RB3-Dimmwert AB 13> Wert auf "100" setzen
Looks like the "wires" for cornering lights (Abbiegelicht) are inverted.
All 12NL should be left=links
All 13NL should be right=rechts
Please compare with
Please compare with
I had to code them that way because with the coding below the right fog comes on when turning left and left fog comes when turning right
