T6.1 fog-light retrofit
D11mat
Looking for some advice please.
I have a T6.1 startline and want to fit factory fit front front lights.
Has anyone done this and can offer advice?
Is there a wiring kit with switch available for the 6.1 or can I use a T6 kit?
I’ll buy the fog lights from VW
Speak to travelinlite I had my t6.1 front end from there, it came with the switch and all the instructions how to fit it and wire it up.
They’ll supply the fogs too as a complete kit
Hello,
On my VW T6.1 from 03/2021, I just retrofitted the front fog lighs + coding.
Unfortunately it doesn't work, and I'm getting crazy as I do not find the root cause.
Now I'm questionning :
- on which fuse are the fog lights connected ? No VW fuse diagram available :-(
- I connected the 2 cables on BNS pins 3 & 45 (refering to vendor) - can anyone confirm I used the correct ones ?
Thanks !!
hello i am writing from turkey what pins are the bcm wiring plugged into for the fog lamp for the T6.1 thank you
Yaptığınız kodlama neydi? Adaptasyon belki?
Bağlantı şeması, 40 (sol) ve 3 (sağ) (kahverengi konektör) pinlerini önerir.
What was the coding you did? Adaptation perhaps?
The wiring diagram suggests pins 40 (left) and 3 (right) (brown connector).
hello Wiring diagram, you said 40 (left) and 3 (right) Which pin will go from switch to bcm?
I would expect there is only one free pin in the switch. If it's pin 9 - it connects to BCM (T73a) pin 47.
Could you please post a picture of the switch connector.
I would expect there is only one free pin in the switch. If it's pin 9 - it connects to BCM pin 47.
yes 9 pin is next to us 47 Virgo pin is not on the side
I'm looking into this as a potential mod. I've just call Travelin-Lite. They won't break the kits out from the bumper upgrade :(
I understand the fog lamps themselves are the same as the T6 ones.
Could someone point me in the direction of where to get the wiring loom from please?
Please post Full Scan report so we can see how the van is configured.
There seem to several different BCMs in T6.1 depending on how van is equipped. There are at least two main variants: 2Q0 937 090 and 2Q5 937 090. Which makes me wonder what are the differences between variants...:unsure:
