T5.1 Heated Windscreen Retrofit Finished (nearly!)
I looked up my backup and found my recent HVAC coding.
Address 08: Auto HVAC (J255) Labels: 7E5-907-040.clb
Part No SW: 7E0 907 040 D HW: 7E0 907 040 D
Component: ClimatronicT5 H02 0508
Revision: 00001K03
Coding: 0004000103
Shop #: WSC 02737 790 50316
ASAM Dataset: EV_ClimatronicT5 A01003
ROD: EV_ClimaAutoT5Basis.rod
VCID: 24475A912FDBF86A91-8070
Slave 1:
Subsystem 1 - Part No SW: 7E5 907 049 C HW: 7E5 907 049 C
Component: Heckbedienung H11 0303
Serial number: XXX-XXXXXXXXXXXXXXXX
I am going to check my Google drive as well and see if I have the adaptation map.:unsure:
I have this from a scan of my Gen Six with full 3 zone climate, not sure if it's any good
Address 08: Auto HVAC (J255) Labels:| 7E5-907-040.clb
Part No SW: 7E0 907 040 M HW: 7E0 907 040 M
Component: ClimatronicT5 H03 0509
Revision: 00001K03
Coding: 0000000103
VCID: 2D5533857CD78B224D-8078
Slave 1:
Serial number: BHB-0010804160015033
Sunday,05,January,2020,20:16:54:44719
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 19.6.2.0 (x64)
Data version: 20190930 DS308.0
www.Ross-Tech.com
Workshop Code: 377 35110 000155
VIN: WV1ZZZ7H License Plate: SHARAN PANEL
Address 08: Auto HVAC Labels: 5K0-907-044.lbl
Control Module Part Number: 5K0 907 044 FP HW: 5K0 907 044 FP
Component and/or Version: Clima-Sharan H18 0204
Software Coding: 0000000408
Work Shop Code: WSC 35110 377 00155
ASAM Dataset: EV_ClimatronicSharan A01005 (VN75)
ROD: EV_ClimaAutoSharaBasis.rod
VCID: 7EF9CAB4F959DABFD5-802A
Fault Codes have been Erased
8 Faults Found:
9474161 - Motor for Defroster Flap (Pin Assignment is the same as T5)
B1090 71 [009] - Actuator stuck
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 128
Mileage: 86403 km
Date: 2043.14.02
Time: 05:08:12
9474417 - Motor for Front Air Distribution Flap (Pin assignment is different so could be changed)
B1091 71 [009] - Actuator stuck
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 128
Mileage: 86403 km
Date: 2043.14.02
Time: 05:08:12
9476629 - Position Sensor for Rear Air Distribution Flap Motor (Don't have one so somehow need to code out)
B109A 15 [009] - Open or Short to Plus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 128
Mileage: 86403 km
Date: 2043.14.02
Time: 05:08:12
9472277 - Temperature Sensor for Rear Vent (Don't have one so somehow need to code out)
B1089 15 [009] - Open or Short to Plus
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 128
Mileage: 86403 km
Date: 2043.14.02
Time: 05:08:12
9496597 - Sunlight Photo Sensor (has one pin that needs swapping, may be ok after)
B10E8 15 [009] - Open or Short to Plus
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 128
Mileage: 86403 km
Date: 2043.14.02
Time: 05:08:12
9496613 - Sunlight Photo Sensor (has one pin that needs swapping, may be ok after)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 128
Mileage: 86403 km
Date: 2043.14.02
Time: 05:08:12
9479189 - Signal Line for Air Quality Sensor (still to be installed, had same fault in T5 panel - no issue)
B10A4 15 [009] - Open or Short to Plus
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 128
Mileage: 86403 km
Date: 2043.14.02
Time: 05:08:12
9480753 - Control/Display Unit for Rear Climatronic (Don't have one and have deselected in long coding but still showing)
B10AA 31 [009] - No Signal
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 128
Mileage: 86403 km
Date: 2043.14.02
Time: 05:08:12
@Spookybear @Robert thanks for the HVAC scans, I don't think the issue is with the long coding as I have the same coding already in the T5 panle, obviously minus the Insulated glass and rear control panel options (mine is a panel van with no rear seating)
@Robert if you did manage to find any SA code that would be great, not sure what info I will be able to see but its worth a try.
There aren't many adaption channels listed and none correspond to heated screen.
As you can see in the wiring diagrams there are some differences, the blower motor might be ok (just needs 1 wire swapping) but the defrost flap motor images are different. It might just be drawn differently but pin assignment is the same for both but still have a fault. I could try and swap the polarity of the motor wires:cautious:
Unfortunately I don't have any security access codes for your module. I presume you already have asked Fernando?;)
yes but this climate panel was not available in the polo. I've asked a couple of places and nobody knows. I don't think the HVAC modules are a commonly modified module and doesn't get much attention:rolleyes:
That is exactly what I was thinking too and I really understand your desire to stick to OEM approach but I am afraid you might end up as I suggested previously.
I will be happy if you prove that I was wrong.:whistle:
Got a rather larger stone to my windscreen last friday and now I'm between deciding to change that normal screen to heated one. To my knowledge retrofitting includes dash button, relay and the windscreen?
My question is about wiring things, I saw some pictures here on forum about the connection:
Heated Window Screen Help
image-jpg.53078
image-jpg.53079
I presume that those "foils" are the electric connection to the heater elements? Where I can get those plastic parts and other required hardware? My glass changer can get the heated screen, but he told me to check the connections first, so that he doesn't have to do anything else than to change the glass. But from what I can see in those pics I can do it afterwards?
Edit: I showed those pictures to my glass changer and he said that I have to get those black plastic parts for the wires before he will make the change. Does anyone have part number for them?
Edit2: Got those part numbers sorted out, cost me 80€; connectors and holders for them, relay, fuses, dash button, wires for bcm.
I am in the process of sourcing parts for this retrofit as well. In case anyone else wants to repeat the build, as Gobi didn't share:
Relay 4H0951253 (I think) - it is a 644 relay
Relay socket 4H0937528
The squared plastic parts come glued to the foil with the glass as well as connectors. There is 4 of them in total - 2 ground and 2 positive.
The connecting sockets are exactly the same as the connectors attached to the glass.
So you need to source:
71973751 - 2pcs
71973851 - 2pcs
The button for the dash:
7E0959622AWHS
and finally the heated windscreen glass:
8579AGNHMVZ15
or even better:
8579AGAHMVZ15 - insulated double glass (green'ish colour) (original: 7E0845099ALNVB)
These part numbers give you AGC, Pilkington and Fyao/FYG with the first 2 obviously better options.
The wiring is shown in this post:
Fuse location:
Relay location:
The only thing I haven't figured out yet is the holders of those plastic squares that connect foils to wires (you can see them in Gobi's post)
I am 99% complete on my heated screen retrofit, it all functions fine just not quite the way I want.
it will work via the separate button setup as most of them are View attachment 57572But I want to control it via the climatronic panel over CAN
(You can just make it out on this pic)
as mine is a T5.1 I have a slightly different climatronic panel which I have fitted the heated screen button to from another panel (all pcb components all seem to be present) but just doesn’t function
So I guess I need to make some edit to the climatronic panel eeprom (if possible) or maybe I need to make some changes to the BCM.
....so does anyone who has the heated screen button In the climatronic panel have an auto scan and an admap of their BCM?
I think trying to retrofit the T6 climatronic is less complicated, You have already T6 BCM
Maybe a little repining is needed
Hello, @Adams
I have the samelooking Climatronic module in T5GP, mine HVAC is 7E5907040AC. I want to bring a heated windscreen button from Sharan's / PassatCC hvac too. Have you succeeded with eeprom mode or a security code?
Thx
