Sound-deadening and Thermal Insulation of Cab
The scuttle is basically the area at the base of the windscreen/back of the bonnet. Typically where the wipers are mounted. Sound deadening here and the bulkhead behind the engine will go a long way toward reducing engine noise in the cabin.
Apologies if this has been covered but what's best to sound deaden underneath the felt trim on the underside of the bonnet please.
What gauge was that? And how much do you think I'll need to buy to cover it all?
I think it was 1.6mm from memory and I covered it all and it wasn’t really any different.
The front wings on the other hand ring like gongs, access from behind the wheel arch liner.
The wheel arch liner sounds beyond my mechanical technicalities I'm afraid
They are easy, remove, clean, cover the back face with 10mm self adhesive foam, press back in place, take and impression of the contact areas, remove and cut out the contact areas, refit with slightly longer screws.
They are easy, remove, clean, cover with 10mm self adhesive foam, press back in place, take and impression of the contact areas, remove and cut out the contact areas, refit with slightly longer screws.
All 4 wheels off type of job?
I used the sound deadening mats, I watched the video from Greg Virgoe (YouTube) and he recommended PeaceMAT XS sound deadening from Ebay.
So bought that and to be honest I can tell you, it made a big difference.
Thanks very much for the reply. It looks easy enough to diy it at home (if you're referring to under the bonnet sound deadening)
I've got the step inserts on my list to do.
I did both front wings at the same time as the front arches as easy to do.
How much material did you use on the front wings and how much on each wheel arch? Thanks
