Scuttle Panel Sound Deadening
ben5560
VCDS User
I think it's definitely made a bit of a difference, I've applied 2mm sound deadening all over underneath the scuttle panel, and some 19mm closed cell foam out the way where the water shouldn't run.
There weren't many pictures of this, so thought I'd share what I did
What materials are you using for this? I have loads of left over Dodomat Deadn Hex from when i did the door panels - is this suitable?
