Thanks in advance for any advice ( good or bad )
My current camper ( T 5.1 ) 12v leisure battery system works well for me and I was aiming to replicate in the T6 due soon. ( 100w solar panel CTEK d250 and 120 Smartpass 100 amp battery and ctek mains charger )
Now with the smart alternator, regen braking etc to think about and more powerful solar panels available, I've been reading up ( thanks to the forum posters ) and wondering if I should
1. Go for the new D250SA and limit solar panel voltage to match with 2 110amp batteries and mains charger.
I am trying to reduce 240v install in the van so the charger would not be built in, I just need a 300W inverter ( no not for the charger ) to meet any 240v loads.
2. Give the cat another goldfish, blow the budget, hide the bills from the wife and go for something more expensive and hopefully more effective.
Follow on question
My current set up allows the solar to charge the start battery when leisure is topped up, the D250SA trickle charges the start battery as well. The trickle charge should take the start battery above the nominal 80% does this matter ? To my mind as soon as the engine starts it will drop the capacity but the smart alt will not kick in until below 80%.
Apologies if this has been covered before... I’ve trawled through as much as possible... I know what to avoid now
Follow on question
