milap
Hello everyone
For a long time I was thinking about retrofitting Side Assist to my car (not VW T6 but Skoda Kodiaq) side assist system.
I was gathering tons of information from multiple forums and ofc read carefully whole this topic (thank You Robert!)
Finally I have decided to start the process.
During retrofitting process I was struggling with multiple issues (parts compatibility, disassembling & assembling car parts, wiring, datasets/parametrization compatibility, coding etc.)
All finally was fixed, except one thing.
My radars are newer 2Q0907686B & 2Q0907685B from different car (Skoda Superb 3V)
After I have connected them to my Kodiaq (2019) and after I have done all the components coding system started to work (I was surprised that I didn't have to change dataset/parametrization)
It was working fine for I while but after few days I have received an error "Automatic calibration not possible" C1115F0 on both modules (not in the same time)
I have also noticed that Dynamic angle offset lane change assist. 1 & 2 values are increasing (module 1 is currently 7,65deg and module 2 is -8,54deg)
There are ofc Static angle offset lane change assist. 1 & 2 values that are both 10,24%
I assume that my problem is that Skoda Superb has different Static value than Kodiaq and that is why my Dynamic value are driffting trying to compensate the static value and after reaching more that -5/+5 deg (some sites are saying that it is even 6 or 7 deg) it is returning error.
Probably static calibration could be a solution but does uploading propper dataset/parametrization for Kodiaq will also set those angles so I will not have to make static calibration?
