Paul Niven
Hello... I've recently swapped my captains seat for a bench and decided to install the genuine VW heating elements in the bench (Existing captains are installed with factory heaters). Unfortunately when I've plugged everything back in I've found that the new seat doesn't work. The drivers seat still works though and from a bit of research it seems that both heaters are from the same fuse?
I've measured the resistance of both drivers and passengers elements and they seem to be 4 ohm which suggests they're in tack and not damaged. I measured the voltage at the plug between brown and ground at 14.4V when the engine is running. There is a third wire of the plug which I'm not sure what it's for, ground??
I'm at a bit of a loose end??? Any advice would be greatly appreciated ?
Could it need a VAGCOM to reset a potential fault?
Thanks Paul
Thanks Paul
