Hi guys, need help usual, fitted cobra coilovers , set to max low, and although the ride is pretty good, the problem is, and I've searched every possible solution to this, but, I keep getting a knocking noise, as if the whole back of the van is going to break off
I changed the rear shocks to standard, tried the cobra damper setting, changed rear shock spring rubbers, setting the chilies up ‘ down, etc... but the knocking sound just won’t go away, when you go over any bump, etc...
Please, what can be the issue?
