How Low??.............. SoLow!
The Van Cave
VW Bus Modification Specialist
T6 Legend
So Low Suspension Is Coming Soon To The Van Cave!
The ultimate solution for static lows will soon be available at The Van Cave. If you want low, this is the kit for you. If you want low and comfortable, this is the kit for you. If you want the best riding, best value, seriously low static lows, this is the kit for you. There is currently nothing else on the market that can offer the combination of ride quality, huge static drops and value for money that you can get from So Low suspension.
If you don’t know how good this kit is, or if you just need a reminder of how good a van running really low can look, have a read of this review from forum legend @Tourershine. He didn’t come to me for this setup, but he's approved the use of his review, which tells you pretty much everything you need to know about this kit.
I'm currently waiting on stock to arrive, but as soon as it does, a set will be making its way on to my T32 demo van and I cannot wait.
Cheers All,
Chris.
How low did you set them? Looking good :thumbsup: any chaffage on your 20’s?
Rear are all the way down and one of the two adjuster rings removed. Fronts have about 17mm of adjustment left, but I’m running machined front top mounts. It’s an empty kombi so not a lot of weight in there.
No rubbing on the back, a very occasional rub on the front outside edges, but only under very specific circumstances.
Very good, don’t let Steve (crs) know you’ve gone to the dark side :fast rofl:
Is there enough adjustment to correct the alignment with the angles altered so far from stock?
Front end is good, rear camber is out, but some adjustable poly bushes would sort it. Rear toe is just in and on the limit of adjustment, but again, could be straightened out a bit more with the adjustable bushes. I like the look of the negative camber and to be honest it needs it to stop the 10” rear wheels fouling the arches.
100% agree with @Tourershine and @ChrisR, I have run SoLows now for over 18 months on Banded Amaroks and had no issues at all. The ride is spot on and I carry some weight with full Caravelle floor rails,rear bench, two seats and three kids. I've drove it to Germany about 3 times and had it rammed with camping gear and a roof box and no problems.
I run it at its highest setting only due to where I work and the amount of speed bumps I have to go over.
