I measured the resistors across from pointed end of fuse to pin3,2, and 1= Good resistor readings.Seems like it would be better to make a replacement using much higher rated resistors, these are clearly not up to the job and burn out.
Measuring across the thermal fuse is open circuit. Will try a new fuse from ebay for about £2. I believe its a 192 degree unit at 15amp.
Original VW part £80, 2nd hand ebay about £45. £2 fuse gotta be worth a try.
Will try soldering after buffing away rust/ impurities- hopefully the solder wont melt when its on highest power. Will post results once done.
hopefully help others here if it works.
